The fuel manifold is the shiny straight tube in the center of xheart's photo. The fuel bleed valve is in the tiny blue cap on the right end of the manifold. The manifold may have plastic cover (Item 4). But you should not need to remove this cover.
But you knew that.
Changing out the Fuel filter
- Has thanked: 987 times
- Been thanked: 1075 times
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Fuel filter can be a pain to replace due to rust - remove the bracket first and then work with separating fuel hoses.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
I threw on a new Mahle fuel filter today. Didn't even bother to raise her. My garage slab is fiber concrete so easy to lay your back on. Don't know if all P2s have it but there's also a schrader release valve on the fuel hose right next to the fuel filter. I just released gas there then changed the filter within 10 minutes.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
A whisper of silicone grease on the new filter's "males" helps.
No relief valving on mine.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
For others picking up this thread... I just did this on my 2008 and pulled the fuel pump fuse to run the car dead and relieve pressure. To my surprise there was a Schrader valve at the fuel filter to drain the remaining fuel out into my drain pan, pretty handy. Don't recall having that on my 2002.
Feels like I picked up 20 horsepower after the filter change.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 11 Replies
- 2114 Views
- 2494 Views
Last post by instarx
- 671 Views
- 2254 Views
- 936 Views
Last post by precopster
