Should I worry?
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
Hello, all, and Merry Christmas early!
I just finished up changing out all 5 spark plugs with new NGK Iridium's and also replaced all five ignition coils with new Bosch ones.
What bothered me was when I pulled the spark plugs from cylinders 2,3 & 4 the plugs were coated with motor oil. Cylinders 1 & 5 were clean as a whistle. Do I need to worry about the oil in the spark plug hole area?
I am due for an oil change after about 5k miles and I did not realize I was driving on a quart low. The car has 171k miles on her.
Been thanked: 4068 times
Probably a tired gasket on the oil filler cap, 1275379
Worry is yet another tool in the Devils toolbox, worry not and be happy.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
abscate wrote: 15 Dec 2021, 23:09 Worry is yet another tool in the Devils toolbox, worry not and be happy.
"When the world is cold, remember this: “Ladies and gentlemen, take my advice. Pull down your pants and slide on the ice.”
-- Sidney Freedman ( MASH ).
Meaning: Deal with what life throws at you but, don't let it consume you.
Active
Past
Mr. Detail
abscate, I replace those rubber gaskets with every oil change. Besides, how would the oil get down into the spark plug holes when that gasket is up on top?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
RickHaleParker wrote: 16 Dec 2021, 00:31 Meaning: Deal with what life throws at you but, don't let it consume you.
How is crankcase ventilation aka PCV?
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Mr. Detail wrote: 16 Dec 2021, 09:27 abscate, I replace those rubber gaskets with every oil change. Besides, how would the oil get down into the spark plug holes when that gasket is up on top?
If it's a bad leak, it pools and runs across the head, into the plug wells, then runs down the block onto the exhaust (which looks like a smokey disaster).
Also - I appreciate the positive words above of not worrying. I saw a sign in a business once: "Worry is a mis-use of the imagination."
<EDIT> I really need to proof read my babblings more.
- Pete -
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Is this the first time you yourself have changed the spark plugs?
Do you do your own oil changes or pay someone else to do it for you?
If it were me, I’d clean out the plug holes (with the spark plugs screwed in still) with some paper towels. Compressed air next. Then continue on with life and recheck the afflicted holes in a couple weeks time. Chances are someone spilled oil when they were pouring it in.
Here’s a marvelous apparatus for eliminating the chance of the aforementioned.
https://www.fcpeuro.com/products/europe ... it#fitment
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
Mr. Detail
Pete, no this is the 2nd time I have changed out the spark plugs. No, I do my own oil changes every 5k miles with full synthetic. No one spilled any oil my friend.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
If I may chime in, like everyone before said, don't worry.
Do clean the plug wells and area above, do check PCV condition, do keep an eye and never trouble the alleged trouble ahead of time :D
...and Merry Christmas!
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
BlackBart
Post by BlackBart »
- Pete - wrote: 16 Dec 2021, 19:09Here’s a marvelous apparatus for eliminating the chance of the aforementioned.
That looks handy. I am always spilling a bit and wrapping rags around it.
And I am always worrying, about everything.
