96 850 Turbo Wagon: what other tires can I mount on my 16" alloy rims?
insession
- Year and Model: 1996 850
- Been thanked: 2 times
Thanks 850oldschool
Yeah, I've had Nokians twice before, and have found nothing beats them if there's water, snow, or ice. In fact although I live in sunny San Diego, I'm looking at their WR G4 - originally an SUV tire but Nokian makes them for sedans as well. Interesting to hear you're the first one who reports modest chafing with the 55's...
- Has thanked: 312 times
- Been thanked: 818 times
I've got 205/55/16's on my 95 850 and no chafing.
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I had aftermarket control arms on, so the steering stops might have been a little different from OEM. The extra fuel economy was welcome, and I made a chart for the speedo correction factors. It all worked out pretty well, but the steering felt a bit more direct when I went back to the 50 series.
insession
Thanks 850oldschool - my mileage strangely actually dropped by a fair bit last I replaced rotor, cap, plugs, and wiring harness. - I had expected the opposite. Surprised .5 up in wheel height affects the economy that much!
- Has thanked: 2209 times
Shouldn't affect mileage much if at all. If mileage changed after changing the ignition parts then something during the fitting of the parts or the type/brand of parts used is out of whack.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
There will be some minor chafing on full lock on the inner protective plastic inside the fender IF steering stops(plastic plates) on control arms are worn.insession wrote: 15 Dec 2021, 19:35 ...Interesting to hear you're the first one who reports modest chafing with the 55's...
Or....if the wheels have the wrong ET.
43 is factory offset for p80.
Anything over 43....49 for example(like wheels from s80) will lightly rub on the front but ONLY on full lock.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Thanks scot850 - yes, I thought so too. Used a high-quality aftermarket kit from fcpeuro, and am thinking that those components can't really be 'wrongly' installed, they either work or don't, and was dismayed that I lost about 2mpg in economy
insession
Would any of you very knowledgeable fellows know how to help me ID my type? 2.3T or 2.3T-5R? Seems to make a diff when looking at tire options here: https://www.wheel-size.com/size/volvo/850/1996/
- misha
Spark plug gap is critical on turbo engines...it must have proper gap.insession wrote: 17 Dec 2021, 18:04 Thanks scot850 - yes, I thought so too. Used a high-quality aftermarket kit from fcpeuro, and am thinking that those components can't really be 'wrongly' installed, they either work or don't, and was dismayed that I lost about 2mpg in economy![]()
Unless you used OE Volvo spark plugs for turbo engine,you need to re-set the gap on new spark plugs since all aftermarket have larger gap.
Cap & rotor must be Bosch,spark plug wires...ONLY Bougicord.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 542 Views
Last post by 5rivers
- 1627 Views
Last post by JRL
- 1893 Views
Last post by Volvo S80
- 9 Replies
- 1351 Views
Last post by V50M66
- 5829 Views
Last post by MadeInJapan
