Slower than Grandpa! How to recover my performance?
- Has thanked: 311 times
- Been thanked: 817 times
Maybe the points are arced? Bad condenser?
- RickHaleParker
- Been thanked: 979 times
Before you start throwing more parts at it, take some vital signs like compression. Smoke test the intake system.
Cylinders maybe getting carbonized. I posted many times on how to remove the carbon with a Seafoam soak.
How old are the Fuel Injectors and O2 sensors? The two can degrade performance without any other symptoms or DTCs. I would go after Injectors before O2 sensors.
It could be a clog in the exhaust system. When was the last time the resonator of muffler where replaced? You can check for a clog in the exhaust system by removing the front O2 sensor. If it runs much better there is probably a clog in the exhaust system. Don't be quick to blame the Catalytic converter. It could be the resonator or muffler.
Active
Past
Past
- RickHaleParker
Your hard to please. Erik gave you a Grandpa answer to a Grandpa question.scot850 wrote: 17 Dec 2021, 11:42 Erik have you been on the eggnog again?It is a 2000 MY = No distributor!!
Active
Past
Past
- RickHaleParker
It's a European car, probably some stole away Gremlins that grew up.
Scott call +1-212-897-1964. ( 1-212-NO-GHOST ).
Active
Past
Past
- 1006 Views
- 30 Replies
- 6192 Views
- 11 Replies
- 4730 Views
Last post by v70XCSteve
- 10 Replies
- 2472 Views
Last post by dux02v70
- 13 Replies
- 2369 Views
Last post by Sommerfeldt
