Found myself looking at an '04 XC70 today. 160K, extremely clean, sticker for an expensive beach, and apparently dealer serviced. Timing belt changed at 135K. I was disturbed by no heat. Blower works fine, couldn't test blending doors. Bringing it up to temp, I felt the heater hoses. One was at best "warm" other seemed ambient. No obvious sign of a heater core leak. My non expert opinion suggests a clogged heater core. Any suggestions of what, or how, I should test for other problems? Since any blockage seems severe, what method to flush?
High beams - this must be a simple one. I hope. High beams work when the stalk is held in the "passing" or "high beam" position. releasing the stalk causes the high beams to shut off. I am looking for suggestions because the relay in my '05 is built into the computer and is a very expensive repair.
Looking at '04 XC70 - no heat - high beams
- Has thanked: 311 times
- Been thanked: 817 times
You have to gamble on whether or not it's the heater core for purchase sake, but seems reasonable it is.
I think I'd pull the core and see if its blocked, yes. But then probably put in a new one rather than mess with flushing it out. Depending on age I suppose.
One question is why did it get blocked? Are other parts of the system clogged up? Hard to address that but something to consider.
Heater cores are full flow. If it’s blocked it’s either a really neglected cooling system or someone used glue in it, aka StopLeak, instrument of the Devil, Faust.
You push the stalk forward on a P2 to get high beams, I think? Check manual for operation.
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
I understand the fear of Stop Leak. As I look around the web, blockage in the core seems a very common problem with Volvos. Culprit seems to be small passages and corrosion. Seems like a very large number of DIY videos on replacing the core in P2 cars. On seeing the price of a new core, circling around $100 as opposed to $584 from Volvo, replacing the core is probably the better job; also, a rather simple one.abscate wrote: 21 Dec 2021, 04:29 Heater cores are full flow. If it’s blocked it’s either a really neglected cooling system or someone used glue in it, aka StopLeak, instrument of the Devil, Faust.
High beams - Electrically speaking, I am on a level with Ben Franklin. The stalk switch, according to my '05 manual, has the normal 3 positions, low beams, passing, high beams. The blue light on the dash comes on and the high beams operate while the stalk is held. This indicates the the bulbs and wiring are correct, leaving the stalk switch, or an intermittent relay. I suspect I had best fool around with the three position dash light switch, which I have never really understood.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Just look in the coolant reservoir for gooey crap (ISO 14001 approved term) to see if someone pooched it. There are far fewer P2 heater core threads than P80 even after adjusting for age in my meta-analysis
Faust
"Gooey crap", good call. I had thought of looking for an "icky" appearance.abscate wrote: 21 Dec 2021, 07:04 Just look in the coolant reservoir for gooey crap (ISO 14001 approved term) to see if someone pooched it. There are far fewer P2 heater core threads than P80 even after adjusting for age in my meta-analysis
2004 V70
- regent
- Year and Model: 2015 XC60 T5
- Has thanked: 2 times
- Been thanked: 12 times
Dr. Faust,
If you want to change the heater hoses on that baby, I have the 30745333 and 30745332 sitting in my garage, pls PM me
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
motormikeyman
- Year and Model: 2004 XC70 AWD
- Been thanked: 8 times
The high beams will only stay on if you manually turn the headlamp switch on. Otherwise they will only come on if you hold the stalk back. It's in the owners manual somewhere.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
First thing I would do is throw a new thermostat in there
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
- 14 Replies
- 4102 Views
Last post by theravenousbeast
- 13 Replies
- 3316 Views
Last post by oragex
- 9 Replies
- 1678 Views
Last post by Faust
- 884 Views
- 1392 Views
Last post by chiefpontiac
