Interesting. I am running a do88 and hadn't noticed a problem with space. But it so happens that I'm planning on working on my fan shroud today, so I'll look into this.
Thanks
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The space isn't an issue, unless you're trying to access something on the front of the engine, or what-have-you. The extra bit helps.
Since I had it apart, I figured I'd do it.
I just realized though, that the shroud I'm using is from an NA car (No additional openings with the flaps), so I'll need to get another shroud and swap it out.
- Has thanked: 1611 times
- Been thanked: 4071 times
Look up what those fans cost. Then wrap it in bubble wrap
- Has thanked: 316 times
- Been thanked: 531 times
$230... ouch. Good thing they're plentiful in junkyards across pretty much all '90s Volvos!
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
I made a new wiring harness for the driving lights in my daughters 850 to replace the cheap components that came with the lights. One of the connectors inside one light had shorted and melted and caused the fuse to blow. Also installed a brand new Interstate battery.
This is all in preparation for her upcoming road trip to PA and then her final semester in Boston where she needs the car for commuting.
This morning I had a fun commute to work with a beautiful sunrise and an odometer "milestone" moment.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
How did you get your US DIM to dispay in Celsius??850 LPT wrote: 27 Dec 2021, 06:57 I made a new wiring harness for the driving lights in my daughters 850 to replace the cheap components that came with the lights. One of the connectors inside one light had shorted and melted and caused the fuse to blow. Also installed a brand new Interstate battery.
- befarrer
- Year and Model: 1998 V70 AWD
- Been thanked: 24 times
Had to change my positive battery cable. Car seemed to be cranking over slower since it got cooler, which is normal. But got to -20, and no start. Boosted it, checked charge voltage, 13.4V at battery, but 14.2v at starter solenoid. Had a 0.8v drop across positive battery cable with engine running, and cable was warm where it connects to lead battery clamp. Used a generic cable for now, charged battery, all seems well now. Old cable had no signs of corrosion, but I bet where the battery clamp is crimped to the wire is corroded under the cover.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
I'm experiencing corrosion at the wire ends of three negative battery cables that I have. I'd like to cut off the corroded ends and attach new terminals. Can anyone recommend good replacement terminals? Or can I clean and reuse the old ones? And should they be crimped, soldered, or both?befarrer wrote: 27 Dec 2021, 16:00 Old cable had no signs of corrosion, but I bet where the battery clamp is crimped to the wire is corroded under the cover.
Maybe it's easier to buy new negative cables, but they seem to have sufficient length for repair.
FireFox31
Napa and west marine are the places I would check out. They can be clamp type. With old wire, I would actually stay with clamp type as the can be disassembled and cleaned of any wicking-type corrosion.
One down side is the nice “ top bolt” vertical tightening clamp is hard to find, you have to tighten on side with an open end 10mm or 11 mm
Much more important to follow the negative first loosen, last tighten protocol as you will touch frame on the side clamp
- 850 LPT
Hi Steve, when you press the two clock buttons you get to choose between four settings/ combinations for clock and temp display. You can change the clock to 12 hour to 24 hour format and temp in Fahrenheit or Celsius. This works for all P80. You have to press the buttons at the same time for a second or two and it's a little finicky, but you can cycle through the options that way.abscate wrote: 27 Dec 2021, 10:57How did you get your US DIM to dispay in Celsius??850 LPT wrote: 27 Dec 2021, 06:57 I made a new wiring harness for the driving lights in my daughters 850 to replace the cheap components that came with the lights. One of the connectors inside one light had shorted and melted and caused the fuse to blow. Also installed a brand new Interstate battery.
13' Honda Odyssey
13' Honda Odyssey
