96 850 Turbo Wagon: what other tires can I mount on my 16" alloy rims?
insession
Year and Model: 1996 850
Post by insession »
Thanks misha. I confess I wasn't aware that the options/choices here were that black/white. Looking at what I got, my wires were NKG's, cap bosch, rotor Standard Motor Products, plugs champion. I will pull them and check the gap. Do you know off-hand what it needs to be for the Turbo?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
0.026"(0.6)or 0.028"(0.7mm).
It is better to re-install your old original rotor instead of that aftermarket junk...which btw....i never heard about.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
insession
Post by insession »
Thanks misha, old parts are long gone ;-)
Re-gapped plugs, they were all around 30+, and not all the same - sigh - took them down to 28. Will see over time if this makes a diff ;-)
Has thanked: 1613 times
Been thanked: 4075 times
It’s MVS lore that Bougicord spark plug wires are the only ones that have been consistently problem free. The are run in close proximity on these cars so any quality issues in the wires will make them crossfire
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
abscate wrote: 23 Dec 2021, 00:52 It’s MVS lore that Bougicord spark plug wires are the only ones
...and it’s fun to say Bougicord!
(How DO you pronounce Bougicod?)
insession
Post by insession »
abscate - are you indicating that there's a way to separate the wires just enough to not have the crossfire risk?
Has thanked: 2212 times
Been thanked: 1853 times
I won't talk for abscate, but there is an area where the wires pass under the top cover just by the top torque mount. This area and the cover can be tight to fit the wires in. I found in one car I had that the spark plug wires were crushed and shorting in that area.
The Bougicord branded parts are recommended as experience of man members is that they are the OE brand and seem to be very reliable. There are other brands out there like NGK and others but we have had mixed reports on the reliability of these brands. I have a friend whose car I worked on recently and saw it had NGK wires on it. Seemed to be running ok.
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 116 times
Post by Goupil »
I like the look of 55 tires on P80s, fills the arches nicely
No rubbing issues on mine but my wheels are ET30 so that helps a lot :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
I've run 205/55/16 tires on my 2000 V70 for a decade. The fronts rub on the plastic at full lock. I've conditioned myself to turn to the lock, then back off a tad. Part of the problem could be my worn out, original suspension.
FireFox31
insession
Post by insession »
Thank you fellows for your kind reports. I regapped my plugs (they were all a bit wide, .30+) down to .28, alas thus far can't tell that my mileage has improved...
