Vida CEM swapping
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Canadian Moose wrote: 30 Dec 2021, 19:05 Will give it another go tomorrow.
When was the last time you downloaded the code?
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Canadian Moose wrote: 30 Dec 2021, 19:05 Tried to crack the pin twice today unsuccessfully on 2007 XC70. CEM p/n: 30786890. Got the first 2 digits the same both times 79, 92 but on third digit got 2 different numbers. Will give it another go tomorrow.
Attach your logs.
Canadian Moose
Year and Model: 2002 V70
Post by Canadian Moose »
The code was downloaded yesterday. How do I go about getting the logs?
Canadian Moose
Attaching serial output. Tried again this morning, no dice.
vl1.txt
(121.52 KiB) Downloaded 135 times
vl2.txt
(121.52 KiB) Downloaded 123 times
RickHaleParker
Canadian Moose wrote: 31 Dec 2021, 08:50 Attaching serial output. Tried again this morning, no dice.
Hardware construction can make a difference. Particularly on the third byte, which is is harder to detect.
Post pictures of your hardware, close up and high resolution. We might be able to spot something.
Active
Past
RickHaleParker
urosm wrote: 29 Dec 2021, 02:12 The connections in the Teensy should be fine, as I read several P2 models without any problems.
All electronics have manufacturing variations. There will be some units that need that extra edge. This project does push the envelope. .001s do add up.
Active
Past
Canadian Moose
Not my prettiest work but you get the idea. :lol:
vtl
Post by vtl »
Code: Select all
diff --git a/volvo-cem-cracker.ino b/volvo-cem-cracker.ino
index e72d843..3a6b14f 100644
--- a/volvo-cem-cracker.ino
+++ b/volvo-cem-cracker.ino
@@ -781,8 +781,10 @@ void cemCrackPin (int maxBytes, bool verbose)
   memset (pin, 0x00, sizeof(pin));
   /* try and crack each PIN position */
-  for (i = 0; i < maxBytes; i++) {
+  pin[0] = 0x79;
+  pin[1] = 0x92;
+  pin[2] = <try placing numbers from top-6 short list>
+  for (i = 3; i < maxBytes; i++) {
     crackPinPosition (pin, i, verbose);
Here's how to start with the third position, try a few bytes from top-3 or top-6, start with 0x97.
vtl
Post by vtl »
Code: Select all
CPU Maximum Frequency:   24000000
CPU Frequency:           180000000
Huh? 240 Mhz? Not 600?
Eh, even 24 Mhz... Something is not right.
Canadian Moose
vtl wrote: 01 Jan 2022, 12:25
Code: Select all
That's a good catch. I must've changed that setting manually last year when I was messing with my 2002 CEM and never changed it back. Gonna try to start at third position and see if it's able to do it. Looks like first 3 are 79 92 and 97.
