When was the last time you downloaded the code?
Vida CEM swapping
- RickHaleParker
- Been thanked: 981 times
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Attach your logs.Canadian Moose wrote: 30 Dec 2021, 19:05 Tried to crack the pin twice today unsuccessfully on 2007 XC70. CEM p/n: 30786890. Got the first 2 digits the same both times 79, 92 but on third digit got 2 different numbers. Will give it another go tomorrow.
Canadian Moose
- Year and Model: 2002 V70
The code was downloaded yesterday. How do I go about getting the logs?
- RickHaleParker
Hardware construction can make a difference. Particularly on the third byte, which is is harder to detect.Canadian Moose wrote: 31 Dec 2021, 08:50 Attaching serial output. Tried again this morning, no dice.
Post pictures of your hardware, close up and high resolution. We might be able to spot something.
Active
Past
Past
- RickHaleParker
All electronics have manufacturing variations. There will be some units that need that extra edge. This project does push the envelope. .001s do add up.urosm wrote: 29 Dec 2021, 02:12 The connections in the Teensy should be fine, as I read several P2 models without any problems.
Active
Past
Past
Canadian Moose
Not my prettiest work but you get the idea.
vtl
Code: Select all
diff --git a/volvo-cem-cracker.ino b/volvo-cem-cracker.ino
index e72d843..3a6b14f 100644
--- a/volvo-cem-cracker.ino
+++ b/volvo-cem-cracker.ino
@@ -781,8 +781,10 @@ void cemCrackPin (int maxBytes, bool verbose)
memset (pin, 0x00, sizeof(pin));
/* try and crack each PIN position */
- for (i = 0; i < maxBytes; i++) {
+ pin[0] = 0x79;
+ pin[1] = 0x92;
+ pin[2] = <try placing numbers from top-6 short list>
+ for (i = 3; i < maxBytes; i++) {
crackPinPosition (pin, i, verbose);
vtl
Code: Select all
CPU Maximum Frequency: 24000000
CPU Frequency: 180000000Eh, even 24 Mhz... Something is not right.
Canadian Moose
That's a good catch. I must've changed that setting manually last year when I was messing with my 2002 CEM and never changed it back. Gonna try to start at third position and see if it's able to do it. Looks like first 3 are 79 92 and 97.vtl wrote: 01 Jan 2022, 12:25Huh? 240 Mhz? Not 600?Code: Select all
CPU Maximum Frequency: 24000000 CPU Frequency: 180000000
- 10107 Views
Last post by RickHaleParker
- 10671 Views
- 27 Replies
- 32564 Views
Last post by cn90
- 10 Replies
- 12592 Views
Last post by jonesg
- 7484 Views
