Cam recenter?
S40Luckey
Year and Model: 2002 Volvo S40
Post by S40Luckey »
After refreshing a new-to-me engine with only 42000 actual miles, I drove it around for a few thousand miles, and for most of that had code P0016. The car seemingly performed fine, so I waited till I had the time.
When i got the time, I set up the car to adjust the timing, set TDC etc, and because I had been working other cars recently, without thinking, immediately released the exhaust cam bolt which I audibly heard let go. I assumed it only went a little, so I then locked the cams with the fixture and crank tool, then set the timing.
The marks on the intake and crank line up, and I can rotate the engine without interference (I pulled the spark-plugs and it spins freely). I tried a brief attempt to start it but it spun FAST, so I know it's not right and there's low compression.
Is there a way to know if the cams are aligned? The exhaust cam is known to be mis-aligned (but which direction)? I was thinking that the only way to know would be to pull the valve cover and visually align them, then install the cover and lock the cams.
Help!?
Mark
S40Luckey
Post by S40Luckey »
For those that may have wandered into this thread, I found the answer. I aligned the cams by setting the writing on the end (the part number) of the intake cam DOWN and the writing on the exhaust cam UP.
Then I set the timing as usual and everything was fine.
OH! and don't forget to reinstall the VVT cap! The car spewed almost 3 quarts of oil in a matter of seconds. It was a mess to clean up.
Mark
