Took my XC90 to get remote starter installed. When the car was pulled inside the shop for them to start work, the horn started, was continuous until they unplugged the horn connections. This took them long since that was not expected. They connected it, and it started again. So now, there is no horn.
What should I do now? I can't remember the last time I used my horn; but I need it. What should I do?
Cheers
Horn Got Disconnected, Now What?
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
http://vidaresources.volvocars.biz/ewd/ ... 998202.pdf , it's for MY07 but you'll be fine.
Horn power comes from the CEM triggered by the steering wheel module (LIN bus). Zero idea what your install has done to make the horn stay on but the EWD may help point out the cause.
Good luck
Good luck
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Keep one in the car while you fix it:
- Roger_850T
- Year and Model: 854T 1995
- Been thanked: 26 times
Do you have Vida and a Dice unit? The horn switch is connected to the Central Electronics Module, CEM, and the CEM controls the horn relay. It would be useful to know if the CEM thinks the horn is activated or not. That will help troubleshoot whether it's the input side, or the relay, or something else. It's conceivable that they got something mis-connected when they did the remote starter. Or, the security system may be trying to activate the horn. Good luck!
Roger
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
05 XC90 V8 213k
Oka
Could not download the PDF due to potential securities. Is this file safe to download so I can disable my security systems to download it.?ggleavitt wrote: 05 Jan 2022, 10:19 http://vidaresources.volvocars.biz/ewd/ ... 998202.pdf , it's for MY07 but you'll be fine.
Good luck
Please, what is "EWD"?
Thanks.
Oka
Am able to download the PDF, however, I am not an electrical diagram reader, am ignorant in that knowledge.ggleavitt wrote: 05 Jan 2022, 10:19 http://vidaresources.volvocars.biz/ewd/ ... 998202.pdf , it's for MY07 but you'll be fine.
Good luck
I had asked what "EWD" is, now I assume it is "Electrical Wiring Diagram".
Oka
Yep I have the tool. What exactly should I be looking for?Roger_850T wrote: 10 Jan 2022, 19:49 Do you have Vida and a Dice unit? The horn switch is connected to the Central Electronics Module, CEM, and the CEM controls the horn relay. It would be useful to know if the CEM thinks the horn is activated or not. That will help troubleshoot whether it's the input side, or the relay, or something else. It's conceivable that they got something mis-connected when they did the remote starter. Or, the security system may be trying to activate the horn. Good luck!
Roger
Yeah, you already told me what to check, but could you be more specific, please?
Thanks
xHeart
The Volvo EWD reference is a must have for us DIYers. Here is a use of "#page=46" in the URL to access and bookmark specific page; here is CEM page. Try this http://vidaresources.volvocars.biz/ewd/ ... df#page=46Oka wrote: 12 Jan 2022, 00:12 Yeah, you already told me what to check, but could you be more specific, please?
- 335 Views
Last post by Oka
- 4110 Views
Last post by MazdaDude
- 837 Views
Last post by beigg
- 1967 Views
Last post by RickHaleParker
- 1360 Views
Last post by jimmy57
