Volvo 850 GLT - Electrical power loss while driving Topic is solved
jmcguire
Year and Model: 1996 850 Sedan
Has thanked: 19 times
Been thanked: 9 times
Post by jmcguire »
My daughter was driving home from work last night and had a temporary total electrical power loss. The car went completely dark for about a second or 2 (headlights, dash lights, radio) then came back on its own.
I took the car out today to try to recreate the issue. I drove it around normally for about an hour and it was running perfectly. On the way home I drove it a little harder and found that if floored the gas pedal then let up on it, the power would go out as the rpm’s dropped. Gauges all dropped to the bottom and the radio shut off. About a second or two later everything came back on and I had to enter the radio code. (I also had a talk with my daughter about her driving habits)
Anybody know what could be causing this? Has to be something electrical and not mechanical… Car starts right up and idles smoothly. No dimming headlights when accelerator is pressed. Power does not cut out when revving engine in park or neutral.
This is a 1996 Volvo 850 GLT sedan with automatic transmission and just over 78,000 miles.
1996 850 Sedan
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
Sounds more like something is "loose", and excessive engine movement is causing the problem. (Based on your description)
Is the battery secured?
Engine mounts good? Grounds all tight and solid?
jmcguire
Post by jmcguire »
Chuck W wrote: 04 Jan 2022, 17:42 Sounds more like something is "loose", and excessive engine movement is causing the problem. (Based on your description)
Checked the battery and the grounds. No corrosion and everything is tight. Upper torque mount was replaced at about 57,000 miles with poly. I’ll check the others tomorrow.
1996 850 Sedan
Been thanked: 4065 times
I would look at the battery feeds first, then the electrical part of the ignition switch if that’s original
Has thanked: 311 times
Been thanked: 817 times
abscate wrote: 04 Jan 2022, 18:38 I would look at the battery feeds first, then the electrical part of the ignition switch if that’s original
aye and aye
Chuck W
Post by Chuck W »
jmcguire wrote: 04 Jan 2022, 17:49
Can you replicate it with a "wiggle" test? Any change while the car is idling when messing with the power/ground and other harnesses?
jmcguire
Post by jmcguire »
After checking all connections, grounds and fuses that I could, I went to the local pick-a-part and pulled the ignition switch from a ‘97. After swapping the ignition switch and taking it for a 30 minute test drive, it seems that the issue is solved. I’m going to order a new ignition switch and install it since I don’t fully trust the used one. Thanks for the help!
1996 850 Sedan
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
It does seem odd that it would be the ignition switch at only 78,000. Still sounds like a loose connection or maybe a connection that somewhat corrodes or a relay that needs to be reseated after many years. A bad ignition switch would certainly cut power as described, but why under sudden deceleration or acceleration. Keep us posted!
All U.S. market models.
All running and on the road.
jmcguire
Post by jmcguire »
Eddystone wrote: 05 Jan 2022, 14:21 It does seem odd that it would be the ignition switch at only 78,000. Still sounds like a loose connection or maybe a connection that somewhat corrodes or a relay that needs to be reseated after many years. A bad ignition switch would certainly cut power as described, but why under sudden deceleration or acceleration. Keep us posted!
I found it odd too, but she does have a few other keys on her key ring and I noticed during the last test drive that the keychain does swing when accelerating like that. The new ignition switch has less key movement when in the run position than the original. If the issue resurfaces, I’ll be sure to let you know!
1996 850 Sedan
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
What DOESN’T make sense about that fix
is the radio losing power. Constant power
from the battery to the radio does not run
through or get otherwise interrupted by
the ignition switch.
