Listed as p/n 9480153 it looks like a box with a thin steel plate with 6 screws. It appears to be self contained. I don't believe it directly shares any fluids with the angle gear housing.
How does this unit work?
Is it filled with high density fluid(s)?
Does it require any service or periodic maintenance?
Thanks to all you reply.
What is the function of the Oscillation Damper??
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
As far as I know it's just a weighted vibration damper. No maintenance needed.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- RickHaleParker
- Been thanked: 980 times
The answer is in the name. It dampens oscillations. Does this by absorbing some of of the energy of a vibration.
It is a passive device, no maintenance required.
Active
Past
Past
YV1LW
- Year and Model: 98V70r
- Has thanked: 15 times
- Been thanked: 4 times
While on the topic of 1998 automatics;
@richhaleparker
I notice you have a '98 C70 listed with the AW50-42. Is that a special version of the 4 speed automatic? While I haven't pulled all the plumbing that would enable seeing the tranny dataplate, my Owner's manual notes that the manual transmission would be a M56H and the automatic would be designated as AW5-42LE.
Do I have my part numbers wrong? There is no AW42?
@richhaleparker
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
Clue regarding that box under the car: Have you ever seen the movie "Speed" with Keanu Reeves?
Don't stop oscillating.
All U.S. market models.
All running and on the road.
- Has thanked: 1611 times
- Been thanked: 4075 times
Definitely check it for an LED readout
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Not to be confused with the legendary device, used to gain entry to the 8th dimension:
Lord John Whorfin : "John O'Connor, install my Oscillation Overthruster!"
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
foggydogg wrote: 09 Jan 2022, 12:33 Not to be confused with the legendary device, used to gain entry to the 8th dimension:
- RickHaleParker
Noting special the AW50-42 was used on a lot of the P80s. See the attached file.YV1LW wrote: 04 Jan 2022, 19:14 I notice you have a '98 C70 listed with the AW50-42. Is that a special version of the 4 speed automatic?
AW50-42LE.pdf- (306.5 KiB) Downloaded 125 times
Active
Past
Past
- foggydogg
I was known to use that exact phrase on several occasions in a professional capacity at work.
- 1901 Views
Last post by BackRoadSeeker
- 478 Views
Last post by Dieselerdie
- 1792 Views
Last post by kdaide
- 13 Replies
- 3435 Views
Last post by Sommerfeldt
- 890 Views
