New Volvo 850 Purchase!
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Hello, I've just won a local auction for a 1996 850. I don't even have possession of it yet, but am starting to make plans. It will be my daily driver. I have no Volvo experience, prior to this. I don't think I've even ridden in one as a passenger.
I tried searching timing belt service life here a few days ago, and didn't find anything that covered a 1996. The Volvo document, I found only went back to 99. The car is low miles, but I expect that even if the mileage limit has not been reached for the original, the time limit has expired. I do intend to look for a sticker to determine if it's possibly already been changed.
I've watched a couple timing belt videos on Youtube, and it doesn't look to be too hard of a job... certainly not like the timing chain videos I watched when considering a Ford 5.4L.
I'm putting together some parts orders.... filters, belts, thermostat, but am kind of holding off until I actually have the car and can go over it myself rather than guessing at what it needs.
The Trac/ABS lights are on... I understand it's most likely the module, which can be rebuilt, but could also be a few other things. Do the brakes function well without ABS? My truck tends to lock the rears up, if the fuse is pulled, as the proportioning is handled by the ABS system.
The engine numbers confuse me a bit. I've looked on the belt cover, and what I see printed there is slightly off from what I see online. B5254S is on the cover, but I believe is' supposed to be an FS?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Oro
Year and Model: V70 XC, XC70+S60 awd
Has thanked: 7 times
Been thanked: 37 times
Post by Oro »
Congrats and enjoy. The P80 is really fun, but it does have some parts that, as you said, just "time out." I bought a really clean, (relatively, 117k) low-mile PNW car about a year ago. I've still had to fix about every possibly thing that afflicts these cars regardless of care and mileage; it does seem to be more age with these than some other makes. The P2 Volvo fixed a lot of this stuff but the P80 should be viewed more as 'BMW needy' than "Volvo reliable" IMO. But none of it is really heinous.
Here's my 'build thread' elsewhere. Not to promote but it may have helpful things. I still have a few things to scratch off the list but now that I've had the car a year (only put 2k miles on it though), I am beginning to like it and not missing other newer cars at all - which says a lot. if you are a DIY guy you will have a ball (and i am guessing "454cid" implies that!). You need to not plan on making it a dd car until you've had time to mess with it, find all the problems, lay it up a few days at a time, etc. I guess you know that.
My car is now my dd car, but for nine months it was not fun as I always found something to fix, improve, or refinish. Now that it is almost done, I'm really pleased with it and this month I'm dropping in a bigger intake, turbo, and getting a ecu tune. These cars handle well. If you are from the old school - meaning you got your driver's license before say 2005 - and had to learn to make car handle instead of just relying upon HP - these are fantastic. OK, I'm assuming you got a turbo...
https://www.swedespeed.com/threads/117k ... nd.639665/
No 454 in the background, but this '32 Dodge adds some credibility chops I hope. ;)
Been thanked: 4071 times
Second prize was 2 850s
Plan on spending about $1500 to get it to daily driver status. That’s after you evaluate it for big warts
Timing belt is a 70k / 6 year item on the 1996. It’s a $2000 repair bill if it breaks or a pulley seizes.
Rear delta links are a tough job especially in Rust Belt , $1000
Pcv check for pressure will tell you oil change history
A smooth running engine and transmission with no leaks or codes sill mean you have a runner. Everything else can be fixed by a wrench
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
454cid wrote: 06 Jan 2022, 20:28 The engine numbers confuse me a bit. I've looked on the belt cover, and what I see printed there is slightly off from what I see online. B5254S is on the cover, but I believe is' supposed to be an FS?
B5254S and B5254FS are the same engine. It the accessories that make the difference.
If it has Fuel injection it is a B5254FS. If it has a carburetor it is a B5254S. Later years Volvo dropped the F Nomenclature because all cars come with Fuel injection. S became Fuel injected naturally aspirated ( non turbo ), same as FS. T became Turbo.
1996:
S = standard (naturally aspirated).
FS = fuel injected standard (naturally aspirated) with catalytic converter.
If you don't know the history of the timing belt, change it as soon as you get it. Keep in mind the PO may of stuck a cheap belt on it. Better to be safe then sorry. The original change interview was something like 70,000 miles. Belt technology has improved in the last 25 years. Go by what the belt manufacture recommends and do not skip on quality to save a few bucks.
Active
Past
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Ditto the above, and welcome to our little Tribe.
If there is any question about the engine service, belt/tensioner/water pump should be on the list early.
Take a good look at the motor mount behind the RF wheel, you'll be there anyway for the belt stuff.
The car is driveable with the ABS light on, just use the same precautions in snow you would've used driving an early big-block.
If the decal with the engine number on the plastic timing cover isn't legible, it's stamped on the block on the passenger side; '96 is early enough that may not be critical for parts info.
Robert DIY on youtube has some pretty good guides for maintenance, and there are plenty of threads here.
If in doubt, come back here, opinions freely given - some may even be helpful.
Has thanked: 311 times
Been thanked: 817 times
Many "low miles" 850s at auction have a broken odometer gear, it is a common failure. If so you can pull the actual mileage from the cluster, it is kept electronically even if the mechanical gear mechanism fails, but it's tricky on a 96.
Brakes work completely fine without ABS. Also check the top and bottom engine torque mounts, these are usually shot.
BlackBart
Has thanked: 967 times
Been thanked: 922 times
Post by BlackBart »
454cid wrote: 06 Jan 2022, 20:28 Hello, I've just won a local auction for a 1996 850.
Did you get the one with the very rare 454 option?
454cid
Post by 454cid »
Oro wrote: 06 Jan 2022, 23:20OK, I'm assuming you got a turbo...
This one is NA, which probably better for my use. I've got a 100 mile round trip for work.
I've started reading your thread, thanks.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
abscate wrote: 07 Jan 2022, 01:49
The rear suspension is something I have not explored yet, via Youtube. I guess I'll have to do that.
I don't feel a breeze when I remove the oil fill cap. I hope I don't have to deal with that now. The timing belt actually looks like an easier job, to me.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
RickHaleParker wrote: 07 Jan 2022, 03:17 1996:
I don't think any vehicles in the US still used a carb, in 96.
I looked for a sticker today, and didn't see one. I'll probably pull the cover in the next couple of says and do a bit of poking around, but at this point, I'm planning on doing the timing belt.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
