Hello,
Under acceleration the car does perfect, no wobble and it tracks straight. If you let off the throttle, there is a slight pull to the left and a noticeable wobble in the left front. What could that be? It is very strange. I appreciate your help!
1994 850 Turbo- Wheel shake when off throttle
- Has thanked: 2861 times
- Been thanked: 1332 times
Sounds like an axle. With a possible failed bushing in control arm.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Agree. Could be a sloppy lower ball joint, too.matthew1 wrote: 11 Jan 2022, 11:09 Sounds like an axle. With a possible failed bushing in control arm.
