I have just purchased an 04, V70 wagon. It is a non turbo, 2 wheel drive, w/approx 138K miles. All the issues seem to be minor but I want things to be right. The key FOB works but the key just swings loose in the FOB. Is there an easy fix for this?
The car is quite dirty inside which will only requires elbow grease, and there is a section of the drivers seat back that needs to be restitched.
My name is Steve, and I am a new member.
- RickHaleParker
- Been thanked: 981 times
2004 V70 would be the switchblade key. You can get replacement Shell Cases. Just transfer the blade, electronics and the RFDI transponder which is the little glass capsule in the head part of the case. Be careful taking out and inserting the RFDI transponder. You can crack the glass, so work it, not force it. The hardest part is getting the spring back in.seh43 wrote: 09 Jan 2022, 17:52 The key FOB works but the key just swings loose in the FOB. Is there an easy fix for this?
Active
Past
Past
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Fellow newbie here too. When I first got my 02 S60 it had a stitch on the drivers seat that let loose too. Local upholstery shop fixed me up while I waited...not perfect but did a good job.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 312 times
- Been thanked: 818 times
Can you name the shop? I might get some stitching done, just knowing a decent shop nearby helps.Krons wrote: 09 Jan 2022, 21:16 Fellow newbie here too. When I first got my 02 S60 it had a stitch on the drivers seat that let loose too. Local upholstery shop fixed me up while I waited...not perfect but did a good job.
- Krons
It was a place in Urbandale, IA next to Blackford Shoe Repair. Pretty sure this was a furniture place...I see there is an alterations place next door that does leather jackets, maybe give them a try can't recall if that was it: Geysa's Tailors & Boutiqueerikv11 wrote: 09 Jan 2022, 21:48Can you name the shop? I might get some stitching done, just knowing a decent shop nearby helps.Krons wrote: 09 Jan 2022, 21:16 Fellow newbie here too. When I first got my 02 S60 it had a stitch on the drivers seat that let loose too. Local upholstery shop fixed me up while I waited...not perfect but did a good job.
Sorry to sidetrack your thread Steve!
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
https://andrewpeng.net/cars/2006-volvo- ... key-repair
This is a great guide for repairing your key. I used LePage All Plastics Super Glue to glue mine back up once I confirmed it was working correctly. Replacement switchblade end on eBay is under $5. I used a dentist's pick to gently chisel/pry my transponder out of my fob. It worked great. But if you break it and don't have a backup, I've heard exorbitantly high quotations for replacing a key (I believe it has to be shipped from Sweden IIRC)
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 1613 times
- Been thanked: 4078 times
Its a $500 experience to make one of those chipped FOB keys for a Volvo Both the new key and the car have to be physically present at Volvo to enable the key to start the car, in short.
- Krons
If you want a replacement key you may want to call around for quotes from locksmiths. There is an independent guy here in town that does some of the chip fobs for a fraction of the dealer price, and they work well. Even comes to your door.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 2866 times
- Been thanked: 1332 times
Our dear moderator Song wrote up this switchblade key fix: viewtopic.php?t=31639
As long as you move the RF chip,from the fob to the new fob ( careful) this can work.Krons wrote: 11 Jan 2022, 18:37 If you want a replacement key you may want to call around for quotes from locksmiths. There is an independent guy here in town that does some of the chip fobs for a fraction of the dealer price, and they work well. Even comes to your door.
Locksmiths cannot program new fobs. Volvos security programming is extremely robust , perhaps best in industry.
