Seems to me that someone posted the exact factory alignment specs for these cars in the forum, and I saved them. Can't find them now, and a search here turns up six million threads. Anyone have them handy?
I've had my 98 V70 in twice and it still isn't done right. Not a mechanical or worn part situation.
98-99 Alignment specs S70 V70? Topic is solved
- Eddystone
- Year and Model: 1967 Ford GT40 Mk IV
- Has thanked: 63 times
- Been thanked: 81 times
All U.S. market models.
All running and on the road.
- Eddystone
lexmia
- Year and Model: 1998 V70
From the Volvo VADIS:
For the 98 V70 Base Model, Auto.
Front:
Caster 3.35 deg +/- 1.0 deg. Difference between sides Max 1.0 deg.
Camber 0 +/- 1.0 deg. Difference between sides 1 deg.
Toe-In (total) 0.33 deg +/- 0.1 deg.
Rear:
Camber -1 deg +/- 0.5 deg.
Toe-in 0.1 deg +/- 0.2 deg
Trust Angle: Vadis states 15 degrees, which of course is a mistake. It should be 0.15
For the 99 V70 Base Model, Auto.
Front:
Same as for the 98
Rear:
Camber -1 Deg +/- 0.5 deg
Toe-in 0.07 deg +/- 0.18 deg
For the 98 S70 Base Model, Auto
Front
Same as for the 98 V70
Rear:
For the 99 S70 Base Model, Auto
Front:
Same as 98 V70
Rear:
Same as 99 V70
Front:
Rear:
Front:
Same as for the 98
Rear:
Front
Rear:
Front:
Same as 98 V70
Rear:
Same as 99 V70
If you do the math on the angle, for those of us who align with string, it’s about 3mm of toe at outside edge of tire and 2mm at the wheel edge, best reference
- V50M66
- Year and Model: 1998 V70 AWD
- Has thanked: 26 times
- Been thanked: 94 times
The best settings for handling are 0.15 degrees of toe in in the front, 0.0 in the back, and factory recommendations everywhere else
Keep in mind this changes slgihtly with different wheel diametersabscate wrote: 07 Sep 2023, 02:59 If you do the math on the angle, for those of us who align with string, it’s about 3mm of toe at outside edge of tire and 2mm at the wheel edge, best reference
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
- 713 Views
Last post by MoVolvos
- 9 Replies
- 1566 Views
Last post by a3inverter
- 814 Views
Last post by darrylrobert
- 13 Replies
- 2941 Views
Last post by gnalan
- 632 Views
