2011 V50 Sunroof Drain Replacement
PooYork
Year and Model: 2011 Volvo V50
Post by PooYork »
I, like others, have been having the dreaded clogged sunroof drain hose issues. I watched some Youtube videos and found one where the guy replaced the multi-part hose with a single hose.
I just did the same, but when I went to run the hose through the hole in the firewall, I could only slip the hose through about a half inch. the part I removed has a two inch or so part that runs through the hole and beyond. Has anyone else done this job and has any advice for me?
1993 Volvo 940SE 200,000
1998 Volvo V70 118,000
2000 Volvo V70 126,000
1998 Volvo V70 AWD 155,000
2011 Volvo V70 110,000
Fairfaxthunder
Year and Model: 2010 V50
Post by Fairfaxthunder »
Hi - I just did this this past summer. After dropping headliner and prepping I too noticed this would be difficult (I think I watched the same video). I heated the end of the tubing slightly to get it into the wider receiving tube (bending carefully) and used a mirror and headlamp to guide it in. No water since. Hope this helps.
