removed the radiator pack again and radiator support, only way to get good access to starter motor
energized the system, turning the key will not crank it
shorting the HOT on the starter motor to the green signal wire , the starter works fines
swapped out the ring antenna from another car .....no difference
Ignition switch? Green signal wire got damaged. I now think the impressive bundle of wires passing through there, containing the green signal wire did take a hit in the crash, probably how the no crank condition came about.
2000 S70 radiator core support replacement need help.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Did you tried to start it in N position?
That signal wire for starter can be replaced,but you need to trace it where it goes through.
Before you dig into that...check if it will start in N position.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Rocket99
- Year and Model: 2000 V70 XC
- Has thanked: 56 times
did try neutral position, no start by turning the key
ran a seperate wire from the starter motor small gauge tab, usually energized by a green wire from the terminal in the motor fuse box .... at the white plastic surrounded connector, then it cranked using the key as normal
What now, thread a single wire from the starter to the fuse box that is clearly normally interacting with the ignition switch??
- misha
You will need the wiring diagram for starter circuit.
Trace the signal wire from ignition switch or fuse box,put it out of use and run a new one.
You don't want a damaged wire from ignition switch or fuse box to dangle around and to cause a short circuit.
Apparently...line from ignition switch to fuse box is ok...damage is somewhere between the starter and fuse box...according to what you said.
So...cut it from fuse box and starter and run a new one.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Been thanked: 4068 times
The starter circuit is impressively complex.
The ignition switch terminal 50 connects to the hot trigger side of the starter relay. The ground side of the relay is grounded by the 2/76 lock controller, under command from the ECU
Both functions , presence of 12V at relay, and logic enabling cranking, have to be functioning to crank
The remote starter terminal at the block does not bypass the PNP switch on an AT car, by the way.
Locked to merge to existing thread
Rocket99
Thank you sirabscate wrote: 14 Jan 2022, 01:03 The starter circuit is impressively complex.
Your info here flew over my head, with time and studying my (somewhat sketchy) Haynes wiring diagram that covers many models I may be able to grok it , I will follow up , try to understand
by running a new wire from inside the engine fuse enclosure (the white plastic one) to the green signal wire, then turning the key did finally cause the starter motor to crank the engine.
my first impulse is to add a small new wire inside a new split loom to replace the apparently damaged green one, hopefully I could get inside the engine fuse box, abandon the old wire and run a new one from that location to the starter
Stumbling around in the dark here
Rocket99
My first impulse is run a new onemisha wrote: 13 Jan 2022, 15:21 You will need the wiring diagram for starter circuit.
I agree I want to find the damaged one and be sure it is capped off, insulated, to head off any short
That square "gutter" conduit stuffed with maybe 100 wires will be near impossible to fully trace that green one. If I can find its other end I guess I could simply route a new wire in new small diameter split loom enclosure into the engine fuse box
The terminal inside the engine fuse box has green with red stripe, not solid green as at the starter motor.
I do need a wiring diagram specific for this model 2000 V70 XC
this is a tough one
I scanned and tried to add the Haynes schematic
shows terminal 50 wire on ignition switch yellow/white becoming Green/ red then entering engine fuse box, Gn/R is visible in engine fuse box at that terminal
starter relay, cube shaped inside engine fuse box, sends current to the signal wire to starter when key is turned to start, shows Gn/R but this car its solid green at starter.
I have no idea what the 2/76 lock controller is
this diagram says signal feed to starter motor is Gn/R but it is Gn only on this car
I need to get into the engine fuse box, perhaps drill new access hole for new wire, looks like the platform in the engine fuse box must release and lift up out of it for access to wires inside
Rocket99
that engine fuse box is definitely made to keep people out of it
What about route the new wire directly into a new hole in the side of it, adjacent to the exposed connector inside, to a spade female connecter on to the spade male?
Tracing the green signal wire from the starter back to "wherever", does not seem to be in the cards
getting a good look at the ignition switch will be worth doing to see if it is there.
Rocket99
"Both functions , presence of 12V at relay, and logic enabling cranking, have to be functioning to crank "
I connected (Jumped temporarily) the termminal in engine fuse block (you call it remote starter ??) direct to the start terminal on the starter motor, normally a green wire. Then using key did crank the engine.
Does this mean making that jump connection permanent, with a new dedicated wire, Inside a new small size split loom, will get this system starting, excluding other starting problems of course.
My superficial understanding of complex Volvo systems is slowing me down big time
- 4902 Views
Last post by volvolugnut
- 3283 Views
Last post by alschnertz
- 18 Replies
- 11360 Views
- 165 Views
- 11 Replies
- 9851 Views
