98 v70 5sp base: pcv behavior? Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
I deliver 40-55 meals per day, of that my car idles 90% of those. Today I left my Volvo idling. I was halfway between car and client's door when I heard a loud 'pfft'. I looked back and saw a big whitish loose cloud of smoke come from under the hood. Not a continuous cloud. A single cloud. I looked at the engine and found the PCV hose had popped off the top of cam cover. I figured there had to be a lot of pressure to pop that off. Is that the case? I did the glove test and the glove did not suck in or totally blow out. The glove oh so slightly has constant blow out; the glove barely inflates but can stand at about a 22.5-degree angle. The catch is that I did not put on a hose clamp when putting the new pcv on back in September. Is there a reason the pop was so loud? Would there be pressure on the hose itself that the glove would not show?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
Interesting. The only thing that comes to my mind is that the diameter of the hose is alot smaller than that of the oil filler cap. Also, that hose might just work itself loose over time and just pop off at any given time.
1996 855 R,
2010 V70 D5,
Has thanked: 2200 times
Been thanked: 1852 times
I have had that house come loose on me before. As the rubber hardens with heat and age it shrinks and comes loose. Try nipping the clamp a bit tighter. Ideally replacing the hose with a newer one is best option but that can hopefully wait until you need to do the whole refresh.
CIK7
Post by CIK7 »
Thank you both for your responses. This makes me feel much better. I thought Id miss a week of work.
