How to fix coolant getting into the oil.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I'm waiting on parts to come so I can put my engine back together as I took the head off to change the gasket. I drained the oil, and it looks like this:
Thoughts? It seems there is coolant getting in the oil, but I'm not sure how. I think replacing the head gasket will fix it. The gasket blew when it overheated, and I can see how coolant gets into the cylinder by the break in the head gasket, but not the oil. How bad does this oil look? In total, about 2 gallons and a little more came out. is this around the oil capacity? I also stuck a magnet in the oil to make sure there were no metal shavings, and it didn't find any. Metal shavings are usually steel/iron right?
2002 v70 X/C 288k miles
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
After thinking over my initial suggestions I've come to the conclusion it's best for you to physically go to a local indie shop that specializes in Volvos and show them those pictures and let them tell you what they think. Just Google Volvo in your area and check the shops rating.
Has thanked: 1609 times
Been thanked: 4065 times
You have a liter or two of coolant in 6 liters of oil. The head gasket sill fix that as Long as the head of block is not cracked, a rare occurrence.
Flush the cooling system with lots of water and look got traces of oil. A couple of oil changes will take care of the engine side
02V70
Post by 02V70 »
For flushing out the oil, can I use old engine oil to do that?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Drop the pan, clean it out, attach back w/o sealant, flush the engine with any cheapest oil of good enough viscosity (Amazon 5w30), drop the pan, clean it out, install, now properly. Use new oil filter with each oil change through the process. Use new sump o-rings. Replace oil cooler just in case (needs two o-rings), Behr is OE and affordable.
It is a perfect time to replace the rod bearings, if you want to go that deep.
justanotherhumanoid
Year and Model: 2006 S60
Has thanked: 7 times
Been thanked: 17 times
Post by justanotherhumanoid »
Might also be a good idea to check both fluids after running for a bit, and potentially do another swap after putting some miles on following the flushes.
If you check them and both are indistinguishable from normal, then you can probably skip the early fluid changes. The check is the important part, and you can verify then that your gasket job is solid as well.
2006 S60 2.5T AWD - Build Log
do88 intercooler, all aluminum radiator, XC90 aux transmission cooler, magnefine ATF filter, Snabb intake elbow & throttle body pipes, custom oval exhaust, rebuilt 16T swap, 17x8" team dynamics pro race 1.2 wheels, ipd sway bars, R brake swap, Hilton tune, sunroof shade that slides open when I step on the gas and closes when I stand on the brakes.
02V70
Post by 02V70 »
vtl wrote: 30 Jan 2022, 10:48 Drop the pan, clean it out, attach back w/o sealant, flush the engine with any cheapest oil of good enough viscosity (Amazon 5w30), drop the pan, clean it out, install, now properly. Use new oil filter with each oil change through the process. Use new sump o-rings. Replace oil cooler just in case (needs two o-rings), Behr is OE and affordable.
When you say flush the engine, do you mean to put oil in with the oil drain plug/screw off, or do I start the engine, run it for a bit, then drain again?
vtl
Post by vtl »
02V70 wrote: 17 Mar 2022, 21:03 When you say flush the engine, do you mean to put oil in with the oil drain plug/screw off, or do I start the engine, run it for a bit, then drain again?
Start engine, run a bit, drain.
MoVolvos
Post by MoVolvos »
02V70 wrote: 30 Jan 2022, 10:43 For flushing out the oil, can I use old engine oil to do that?
Have you checked to see if your radiator and trans fluid is okay also. Since it overheated the pressure could possibily compromise the radiator? The trans fluid is also cooled by the radiator's trans cooler section.
You can use old engine oil. Run engine at idle for 5 minutes till the it is mixed (check) and then light driving for a few mile and drain. If you have more used oil I would recommend using it for a second flush before spending money on fresh oil. Would buy the cheapest oil filter and replace for each used engine oil flush.
Cheapest Oil At This Time
$65.99 ($16.50 - 5 Quarts) Costco - Kirkland Signature 5W-30 Full Synthetic Motor Oil 5-quart, 4-pack
https://www.costco.com/kirkland-signatu ... 90432.html
$17.82 - 5 Quarts Shell Rotella Gas Truck Full Synthetic Motor Oil 5W-20, 5 Quart
https://www.walmart.com/ip/Shell-Rotell ... /882258536
$20.37 - 5 Quarts Pennzoil Platinum Full Synthetic 5W-30 Motor Oil (5-Quart, Single) Amazon Link Not Working On Page!
https://www.amazon.com/Pennzoil-Platinu ... r=1-4&th=1
02V70
Post by 02V70 »
Is radiator fluid coolant? Also for flushing the cooling system, would I fill it up, run for a bit, then drain it like the oil, or put water in it while it is draining out. It is safe to use water without coolant in it right?
