Limit to how many times tensioner can be recompressed Topic is solved
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
So this will be the third time I'm recompressing my tensioner. Is there a limit on doing this ? This tensioner is new with 0 miles.
I have another one that has only been recompressed once, but it has 20k miles on it. Which would you use ? When I compress them, I do it over many many hours. I just take it and the clamp into the house, and give it a little turn every so often. But I'm worried that they might lose some of their " push " after repeated compressions.
1999 V70 GLT
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Just an uneducated guess, but I think you should be good with a few slow compressions. The amount of movement over time will definitely equal more than 3 full compressions.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Has thanked: 293 times
Been thanked: 765 times
I would have no concerns at all with the 20k one as long as you are confident about how it has been compressed in its lifetime.
On a pesky timing belt job I have certainly had to recompress 3-4 times before; I assume that as long as you go slowly the hydraulic mechanism won't know it's been compressed. But I've never seen the mechanism!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
If there are no signs of leaking when you remove it from the car,if it's hard to compress it and if it doesn't leak while compressing or after it's been compressed...reuse it.
You don't need to wait for hours to compress it...just take your time and do it slowly...around 30 min.
I'm on 4th timing belt now and tensioner was compressed around 4-5 times during it's lifetime and it's still original.
Mileage is close to 400k km.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1507 times
Been thanked: 3822 times
Have we ever seen a failure on this part?
misha
Post by misha »
I didn't.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Clemens
Post by Clemens »
Those who have might not be riding the p80 train anymore.
Summer: 1996 855 R
Donor: 1995 854 10V
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
In one of Robert DIY's videos he mentions to check for silicone oil seeping around the piston -- that's a sign of a failed internal oil seal.
mecheng
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Do you have to compress it slowly to prevent heat building up too quick?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
misha
Post by misha »
1/4 or 1/8 slow turn in a big vise every min or two.
The key is not to force it while compressing.
When it is compressed,insert a pin to lock it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
