So this will be the third time I'm recompressing my tensioner. Is there a limit on doing this ? This tensioner is new with 0 miles.
I have another one that has only been recompressed once, but it has 20k miles on it. Which would you use ? When I compress them, I do it over many many hours. I just take it and the clamp into the house, and give it a little turn every so often. But I'm worried that they might lose some of their " push " after repeated compressions.
Limit to how many times tensioner can be recompressed Topic is solved
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Just an uneducated guess, but I think you should be good with a few slow compressions. The amount of movement over time will definitely equal more than 3 full compressions.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 311 times
- Been thanked: 817 times
I would have no concerns at all with the 20k one as long as you are confident about how it has been compressed in its lifetime.
On a pesky timing belt job I have certainly had to recompress 3-4 times before; I assume that as long as you go slowly the hydraulic mechanism won't know it's been compressed. But I've never seen the mechanism!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
If there are no signs of leaking when you remove it from the car,if it's hard to compress it and if it doesn't leak while compressing or after it's been compressed...reuse it.
You don't need to wait for hours to compress it...just take your time and do it slowly...around 30 min.
I'm on 4th timing belt now and tensioner was compressed around 4-5 times during it's lifetime and it's still original.
Mileage is close to 400k km.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Have we ever seen a failure on this part?
- misha
I didn't.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Clemens
Those who have might not be riding the p80 train anymore.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
In one of Robert DIY's videos he mentions to check for silicone oil seeping around the piston -- that's a sign of a failed internal oil seal.
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Do you have to compress it slowly to prevent heat building up too quick?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- misha
1/4 or 1/8 slow turn in a big vise every min or two.
The key is not to force it while compressing.
When it is compressed,insert a pin to lock it.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 1814 Views
Last post by precopster
- 26 Replies
- 5039 Views
Last post by Petskoi
- 22 Replies
- 1926 Views
- 3935 Views
Last post by Integrexman
- 2382 Views
Last post by waffleshill
