2002 S60 HOWTO: Replace Hard Lines in-place Power Steering Topic is solved
This topic is in the MVS Volvo Repair Database » 2002 S60 Power Steering – Replace Hard Lines
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Re: 2002 S60 HOWTO: Replace Hard Lines in-place Power Steering
Post by Blacklab467 »
Great writeup on a real dirty job! I've had the displeasure of doing this job a couple times. You went "full commitment" when you snipped off the old lines. Apparently that Fluid Film will prevent rust developing on the new parts.....its good stuff. I've had good success with Crowfoot wrenches on the lines on the rack but mine weren't nearly as rusty as yours. Good Job!
2003 XC 70 (sold)
Has thanked: 1505 times
Been thanked: 3818 times
I just realized the shuttle lines on the rack can be ratcheted on if you do the hard ones first, then bring the ratchet back along the line and take it on the easy access side , where you can use a Crows foot.
Enotslim- I saw Millie the 1998T5 the other day, 5 rivers has her up and running! Thanks again for your generosity
