Continuing the saga on the AWD
Rear toe in is set by ambushinga bushing and eccentric washer , with a long through bolt with a groove to set up the toe. Of course, the long bolt is now NLA
Im going to figure out the bolt size, thread, and length and have a slot machined in
Anyone else interested in some spares? I’ll run a batch of these.
Note,,,the later bolt used on XC70 and XC90 is too short and won’t work here
1999 2000 AWD REAR axle toe in adjustment 986933 NLA, making up my parts
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
What is your strategy for ambushing the washer? Is that how an alignment shop would do it...??
- Has thanked: 311 times
- Been thanked: 817 times
I'll help set up the ambush if you want a consult there.
Nyuck Nyuck Nycuck
I got an eccentric washer and a strange dryer in my basement
Here are the details in the adjuster. This is not going to be easy to make.
You have to put a hex boss inside the cap head on an M12 bolt in 10.9 steel
One obvious solution is tack weld the adjuster washer to the head
- Has thanked: 2199 times
Or I pull you a couple from my stash! I have a couple of spare sets. One I will keep. Let me know. Check what other stuff you need and I can keep chucking stuff in a box if I have them spare!
The rear parking brake back plates are NLA, so suggest you get the feelers out for those. Might be worth trying to find southern or west coast cars where salt is seldom used, same with the rear subframe. They need to cut them to remove them on the caliper side otherwise the rear hub has to be pulled to remove/fit them. If they are cut, then bend them around the hub to fit and then a coupe of tack welds on the cut to repair.
- BlackBart
Don't put the washer in the dryer, you don't want those to shrink!abscate wrote: 09 Feb 2022, 12:19 Nyuck Nyuck Nycuck
Managed to find and order two spares. New part is one piece on the head , the other washer and nut are later P2 parts and are still available
Maybe it is just the angles in the picture, but are the bolts the same diameter?
vegvariatti
- Year and Model: 1999 V70XC
Dear Abscate,abscate wrote: 09 Feb 2022, 14:16 Here are the details in the adjuster. This is not going to be easy to make.
I 'm about to have those axle bars changed and then adjust toe, and while bars are already on the shelf, still cant manage to find the bolts. Any idea you have this ordered from? It's a '99 V70XC just about to getting a little back to factory condition.
- 10 Replies
- 4908 Views
Last post by erikv11
- 1134 Views
Last post by sandiegoman
- 760 Views
- 152 Views
Last post by VPrints
- 16 Replies
- 2123 Views
