It does stop it draining as it is a one way valve. Once closed water dos not drain back down as it is in vacuum.
Windshield washer check valve?
- Has thanked: 2215 times
- Been thanked: 1853 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I never thought of it that way. I did actually use vacuum to change the valve on the bottom of my water heater in my house. Close the intake and outlet valves on top and most of 40 gallons is held inside while I removed the leaky drain valve on the bottom.scot850 wrote: 10 Feb 2022, 15:58 It does stop it draining as it is a one way valve. Once closed water dos not drain back down as it is in vacuum.
I did notice that the driver's side hose looked a little different than the passenger side, so maybe I've had one or both check valves removed and replaced with simple fittings, at some point by someone not knowing any better, or maybe just an internal failure.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 15 Replies
- 8927 Views
Last post by volvolugnut
- 36 Replies
- 25047 Views
Last post by StickyPocket
- 532 Views
Last post by ZionXIX
- 4492 Views
Last post by eyerollXC70
- 555 Views
Last post by Duncx
