VIDA 2014D_Repack install on Windows 10, any version.
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
RickHaleParker
Been thanked: 958 times
Re: VIDA 2014D_Repack install on Windows 10, any version.
Post by RickHaleParker »
JanDzbanowski wrote: 30 Jan 2022, 09:02 Unfortunately nothing seem to help. Do you guys have any idea how to get it to work?
You might try:
1. Uninstalling VIDA, SQL and Mongoose Drivers.
2. Manually delete the VIDA folder in C:\.
3. Use CCleaner to clean up the Windows Registry.
4. Run the CCleaner Registry cleaner over until it finds no issues.
5. Reinstall everything using the scripts as instructed in the guide.
I think there maybe some artifacts in the Windows Registry from the first install. That do not get removed by the uninstaller.
There is a reason install .net framework 3.5 is the first step. It is about getting the windows environment ready.
RickHaleParker
Note: You can run VIDA in Microsoft Edge without the IE Tab extension, if you enable IE Mode in Edge and add http://localhost/Vida/ to the page list. You you will need to add http://localhost/Vida/ to the page list every 30 days.
I don't have Windows 11. But working with a somebody else we have confirmed IE TAB works in Windows 11. IE TAB is the better way to go.
les2050
Year and Model: 2008 V50
Post by les2050 »
error.
les2050
Post by les2050 »
hi all, these instructions and guides are brilliant!! much appreciated, defo switch of windows security built-in and i ran all patches right click run as admin with no issues. I have it all installed on win 10, can I use any obs2 to USB like?
Vgate vLinker FS OBD2 USB Adapter for FORScan HS/MS-CAN Auto Switch ( amazon )
or
V160 JLR PLUS Mangoose SDD Pro For Jaguar and Land Rover Support till 2017
any help would be great.
RickHaleParker
For Windows 11 follow instructions above. Then install the IE TAB extension in Edge or Chrome. Use the extension to connect to and rendered VIDA.
RickHaleParker
les2050 wrote: 26 Feb 2022, 12:37
or
Read this.
Stu70
Year and Model: 2006 Sonic VR GT
Has thanked: 34 times
Been thanked: 26 times
Post by Stu70 »
2. In Windows File Explorer navigate to the 2014D_Repack.iso. Select, Left click then Mount
I’m having difficulty with the above term ‘mount’ . I navigate to the iso. I select it … then I’m not sure what to do.
The last time I was this far into a computer was programming my ZX Spectrum in 1988…
1998 S70 10v BiFuel - Sold
2006 Sonic V70R - “this is going to be expensive “
RickHaleParker
Stu70 wrote: 26 Feb 2022, 15:18 I’m having difficulty with the above term ‘mount’ . I navigate to the iso. I select it … then I’m not sure what to do.
Select the ISO, Left click and select mount from the list
Once you mount an ISO it behaves like a disk in a DVD drive.
2022-02-26 (1).png (222.04 KiB) Viewed 2630 times
Stu70
Post by Stu70 »
Thank you RickHaleParker - I had to download a mount app. My windows 10 didn’t have that window in your top picture.
I really appreciate the way you’ve written these instructions, the time and effort you’ve put in and the patience you show.
LozinOz
Year and Model: 2012 XC60 D5
Has thanked: 3 times
Post by LozinOz »
Hi
First time installing VIDA - on Windows 10 laptop - thank you for effort and detail provided in setting up, including running the x64 version of ‘EnableIEHostingxxx.reg’ mentioned. I believe I followed instructions exactly, seemed to go fine, have managed to log in, enter my cars VIN & VIDA correctly decided my cars basic information. BUT that’s as far as it allows me to go ie: the ‘Diagnostics’ tab is not active, and the ‘Information’ tab is not populated with my cars information. - error (pop up) I’m getting on these (as shown in attached picture) is ‘GetCommToolSettingsObject(…)DiagnosticsAllowed is not a function’ - I’m at a loss what to do now. I’ve rebooted PC tried more than once - sane message.
I had a brief look at logs but with so much detail there I’m not sure what to be looking at. If relevant I’m based in Melbourne Australia (in case location affects operation / function)
Any assistance greatly appreciated
Thanks
Loz
