Maybe a transmission issue?
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
I think I have a tranny problem on my 2004 S60 2.5T with 186k. My car is making a clunking sound when I give it gas & when I let off. Only notice it in stop & go traffic. Seems to do it in auto or geartronic mode. Only had the car since Feb. 2021. Last June I had the tranny fluid replaced with Valvoline Maxlife. There are no codes & the car drives fine otherwise. I tend to panic in these situations. Could this me a bad motor mount? Any thoughts would be helpful.
Pat Callaghan Jr.
98 S70 GLT
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Could be bad motor mount, could be CV joints. Checking the bottom front and top mounts isn't hard to do. A bit more work to get to the passenger lower mount. All three of these are pretty straightforward DIY, the other two a bit tricky.
I'd check mounts and CV shafts before worrying about the trans.
08 C702.5T (sold)
The non-Swedes:
- Pete -
Has thanked: 80 times
Been thanked: 175 times
Post by - Pete - »
I think your suspicion of a collapsed motor mount is probably pretty likely. Although, anytime you are on the throttle & then let off, the front suspension gets loaded a bit also. Just saying have a real close look at all 5 engine mounts but also inspect the moving pieces that make up your suspension as well: control arm bushings, ball joints, top end of front strut assemblies ie top bearing plates & spring seats etc.
Typically transmission maladies present themselves most notably at shift points, whether it be up or down shifting. From your description it seems to me as if the car is still shifting well.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
patcal
Post by patcal »
Thank you. I tend to always think the worst. The car shifts great up & down. No delayed shifts or anything I have read about these transmissions. I am now off to read up about mounts & CV testing.
Pat Callaghan Jr.
98 S70 GLT
- Pete -
Post by - Pete - »
The round hydraulic engine mounts (X2 in P2’s) would be lowest on my list of culprits. I do think it’s important to check them though. Here’s a couple effective ways to check them. Use a jack & 2x4 under the oil pan & gently lift the engine up. If you can hear slurping and gurgling noises emanating from either of the hydraulic mounts, their contents have been spilt by a split in the rubber (usually presents itself as a rusty looking stain around the area of the mount that is impossible to remove). Like I mentioned, I doubt the noise you’re hearing is due solely to a failed hydraulic mount, but if you find one is failed I would highly recommend replacing it. When these fail, the engine can move/vibrate/oscillate in a manner it wasn’t designed to. This, in turn, can lead to a premature wearing of your CV axle’s cups & rollers (a bad thing).
For the other 3 mounts (top torque, bottom torque, and mount by crank pulley) you’ll have to use your best judgment.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Pete -
Post by - Pete - »
One more thing to check, make sure all the fasteners securing the front subframe to the main frame are tight. There’s a slim chance one has loosened. There’s also a slim chance of a worn subframe bushing. All things to consider while you’re at it.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
Has thanked: 293 times
Been thanked: 765 times
I had a P80 Volvo with a bad control arm that clunked like this. The bushing was shot where it mounts to subframe. How old are the control arms on your car?
I could replicate the clunk in the garage by shifting the trans back and forth between F and R so I had a helper do that while I listened around various places. It was pretty easy that way to pinpoint it to the wheel area on one side. No clunk whatsoever when shifting with the front of the car in the air on jack stands though this is not the best counter-test. Replaced control arm, solved it.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 114 times
Been thanked: 263 times
Post by Blacklab467 »
Mine did that about six months ago, it was a precursor to the passenger side CV joint failing. I was concerned about the transmission as well until it developed into an acceleration vibration that gradually got worse and and undriveable. Telltale sign of CV joint failure in my case.
2003 XC 70 (sold)
