I have a question for the suspension gurus or anyone...
2007 S60 2.5T 115K is ready for suspension rebuild. I have done this susp rebuild in 1998 S70, 2004 V70, 2005 XC90...
This is my plan:
- Bilstein B4 Struts (probably better than Sachs)
- New Spring Seats
- New Spring Mounts
- The Coil Springs themselves: can I re-use them? I don't see report of these broken before 200K?
Please advise.
2007 S60 2.5T 115K Front Coil Spring question...
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Absolutely. Although I have broken front and rear coil springs well before 200k, a few times. Salt exposure, no doubt, has influence on this. If the springs aren’t super rusty & pitted (and ride height hasn’t sagged noticeably/too much), I wouldn’t hesitate to reuse them.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Been thanked: 504 times
Thanks Pete,
Only very minor minor surface rust. Nothing big.
I guess I can re-use them.
Then plan to replace them at 180K-200K.
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
I had a coil spring break on my 2004 XC70 at about 100K, lots of reports of similar incidents at VolvoXC.com. They are pretty cheap to replace. I replaced the springs, the spring seats and the sway bar end links. If I had to do it again, I would use the Sachs quick struts, but they were out of stock everywhere at the time. For $250 a side, I wouldn't have to touch anything for 75-100K mi...
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Your equipment has aged to it being stressed and unsafe -- criteria is age, mileage, salted roads, and extreme weather NOT just mileage. Replace Spring!cn90 wrote: 15 Feb 2022, 21:33 Thanks Pete,
- Has thanked: 1613 times
- Been thanked: 4078 times
Ive never broken a spring on FWD cars except for two infant failures of SACHS quick struts
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
If you're changing out the struts, I would suggest definitely getting seats and mounts, Volvo brand only. The original springs will be fine provided they are not rusted and your OEM springs would be the first choice for a replacement brand if you do have to replace them. Spring steel doesn't wear out or sag unless it becomes altered chemically "rust", or impacted or struck. Just check the painted coating on the springs before you reinstall them. At 115K miles I find it hard to imagine that the strut themselves are worn out if they're OEM, these struts last a really long time!
2003 XC 70 (sold)
- Has thanked: 312 times
- Been thanked: 818 times
I've never had a spring break on any FWD (or any, actually) Volvo and breaks are uncommon even on the forums where people get fooled into thinking the problems they read about represent a random sample. 115k is nothing, those springs are fine and will almost surely outlast whatever struts and hardware you install onto them. New spring seats and strut mounts of course, if you decide you want to get new struts.
On the contrary consider yourself lucky, the Sachs quick-struts can be junky.Herb Goltz wrote: 16 Feb 2022, 08:59 I had a coil spring break on my 2004 XC70 at about 100K, lots of reports of similar incidents at VolvoXC.com. They are pretty cheap to replace. I replaced the springs, the spring seats and the sway bar end links. If I had to do it again, I would use the Sachs quick struts, but they were out of stock everywhere at the time. For $250 a side, I wouldn't have to touch anything for 75-100K mi...
