940 turns but won't catch. Was driving along when car shut off, dash lit up, and would not restart. Have so far replaced: cap, rotor, spark plugs, cables, fuel pump relay, fuel pressure sender, crankshaft position sensor, and MAF. Inline fuel pump is working, battery is ok. Car still does not start.
What did I miss?
940 crank, no start... options?
nmontague81
- Year and Model: '96 854, '93 945
- Has thanked: 2 times
- Been thanked: 2 times
- Has thanked: 987 times
- Been thanked: 1078 times
Do you know if you have spark at the plugs? Do you know if you are getting fuel out of the injectors? Do you know if you have leaks in the air intake downstream from the MAF?
Any of these can be your problem. Identify the problem before you replace more parts. Throw parts at the car will likely only deflate your wallet.
nmontague81
Problem solved: water pump gaskets were cracked, allowing coolant to flood the engine and bog it out. USE ONLY OEM or OE GASKETS.
- Has thanked: 1611 times
- Been thanked: 4075 times
Oooof
- 3655 Views
Last post by Empathron
- 1048 Views
Last post by mike:
- 1119 Views
- 408 Views
Last post by JimBee
- 1833 Views
Last post by Littlelegs
