no rear wheel drive!
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 23 times
- Been thanked: 125 times
Re: no rear wheel drive!
Cooled down vehicle parked on level ground with a wheel chocked for safety, reach up under the vehicle and try to rotate the driveline. If it rotates to any degree, your angle gear is stripped. If that's the case, I'll send you a link so you know what's next (assuming you want to keep your AWD). Sometimes the bevel and sleeve are not stripped enough to do the manual validation, then it's all four wheels up in the air and a running vehicle to check.
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
- Has thanked: 1497 times
- Been thanked: 3810 times
That’s a p3 chassis isn’t it? Is that the same generation Haldex?
- ggleavitt
Not sure who that question's addressed to, bevel gear is a bevel gear and if it's shot it's shot. If it is, can see here- https://www.swedespeed.com/threads/2008 ... ar.309585/
Another link on Haldex versions and the XC90, little dated- https://www.swedespeed.com/threads/xc90 ... me.502434/
At some point I'll crawl up under both mine and get some photos of what they look like. Pretty sure they're Haldex Gen3.
I’m free Friday and Monday on port Jeff if you want to play with it
I’m not sure DEM pump trouble leads to codes On these, I’ll hunt for threads
- ggleavitt
I brought up the mechanical check as I purchased a 2008 V8 Sport in 2015 and by 2016 I had already stripped out the angle gear. Check AOC pump and DEM for sure but if you can turn the driveline with your hands, you need to go no further.
Were it not a V8, I would not have suggested trying this test first. Xemodex has a decent troubleshooting flow for the back if the problem not mechanical and not code specific- https://xemodex.com/us/dem-diagnostic-f ... xc70-xc90/
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
I can't turn it by hand with all 4 wheels on the ground.
I just haven't been able to get it lifted off the ground, I know someone at shop who will lift it for me. I had 4 Jack stands but can't find 2 of them...we moved into the new house over 5 years ago and I still can't find tools. I literally work 7 days a week and haven't had a real day off in years but I gotta get this taken care of this. I really dont want to do any more damage so we haven't really been driving her.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
- shiloh51933
I never thanked you for offering help personally, that's real kind of you.
- shiloh51933
I really like that flow chart from Xemodex, real easy to follow. What do mean by checking the AOC Pump? Try jumping it with a power probe? Unfortunately the VIDA program I purchased on Ebay doesn't work, the DICE works. I think VIDA would help with this issue.ggleavitt wrote: ↑05 Mar 2022, 09:24 I brought up the mechanical check as I purchased a 2008 V8 Sport in 2015 and by 2016 I had already stripped out the angle gear. Check AOC pump and DEM for sure but if you can turn the driveline with your hands, you need to go no further.
How would you go about checking the DEM?
In port Jeff this week until Thursdayshiloh51933 wrote: ↑13 Jun 2022, 14:05I never thanked you for offering help personally, that's real kind of you.
