2007 S60 2.5T 115K Front Coil Spring question...
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
erikv11 wrote: 19 Feb 2022, 23:05 My remedy for quick-struts, picked it up cheap from a body shop that upgraded:
I've done three sets since I bought it a year ago, has paid itself off as far as I'm concerned.
For the rest of us :) https://www.ebay.com/itm/165021127842
Has thanked: 1611 times
Been thanked: 4075 times
I have the ABN spring compressor which now has 5 spring jobs /10 springs under her belt so it’s now free. It save me from having to pay for new springs on 3 of those jobs.
It was a huge saving on the Bavarian money waster
It has safeties on the spring which are a really nice feature.
That’s a nice piece of kit , Erik. It Can also be used on toxic dates
One of the sachs kits fired off in the driveway , with the car stationary. Obvious spring defect from pics. Full warranty replacement by credit to new parts, and was lucky enough to get new tire covered fully under road hazard
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
vtl wrote: 20 Feb 2022, 00:58 You can get B6 for XC90 and use your original springs, ground clearance would be about the same, maybe inch higher. But they are expensive as hell: a pair of B6 struts for XC90 costs as much as the whole 4 corners B8 kit for Tundra.
Is the 1" higher a ride height change -- from center of hubcap to fender?
Agree with rest of us spring compressor experience:
vtl
Post by vtl »
xHeart wrote: 23 Feb 2022, 07:38 Is the 1" higher a ride height change -- from center of hubcap to fender?
Ground to fender.
xHeart
Post by xHeart »
Been thanked: 504 times
Post by cn90 »
Hi guys,
The P.O. installed some junk Chinese struts from Autozone, needless to say, it is kaput causing the coil springs to rub against itself when hitting potholes. Just surface rust where the spring coils touch each other when compressed.
But I have decided to replace them for peace of mind...
I need your help re Coil Spring (Lesjofors etc.)...
Build code sticker in RR door jamb says: 23ADX6145681.
Per IPDUSA website, my coil spring is "23".
https://www.ipdusa.com/Articles/524/Wha ... It-Tell-Me
I looked all over FCPEuro website but could not find Lesjofors that has code 23:
https://www.fcpeuro.com/Volvo-parts/V70 ... d=586&v=97
Questions:
1. What is code 23, is it normal spring or stiffer spring?
2. Are all these springs compatible, let's say at factory is spring A, can you install spring C now, and vice versa?
3. What is considered sports spring, i.e., a bit stiffer than "normal duty"?
I prefer something a bit stiffer than stock.
I already bought Bilstein Struts (B4 type).
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I recently replaced all my coils to Lesjofers. What I did was lookup the OEM Volvo part numbers for my car and then cross reference them to the Lesjofors part number. I called FCP euro with my VIN to confirm the correct springs before ordering. I went with standard as opposed to heavy duty and am happy with the results. Hope this helps.
2003 XC 70 (sold)
Post by cn90 »
FCPEuro lists tons of choices for Front Coil Spring, depending on the build code.
However, Rmeuropean.com and autohausaz.com list ONLY one type of coil spring, which is 9465464.
I assume 9465464 is "normal-duty" spring?
Post by cn90 »
The photo shows Chinese strut.
I assume the springs are from Volvo factory.
Could someone check your car and tell me if it is normal for the spring to develop rust where the individual coils "kiss" each other on road bumps? If so, I might keep these springs bc the S60 springs are known to last some 200K?
If the strut is good, the individual coils won't touch each other.
OTOH, when the strut is kaput, there is no more dampening action, the individual coils are allowed to "kiss" each other?
Has thanked: 312 times
Been thanked: 818 times
cn90 wrote: 01 Mar 2022, 20:42 The photo shows Chinese strut.
Not sure why you assume that, do you see Volvo factory paint markings or something else that is not shown in the pic? My first assumption would be that someone installed a quick-strut, with junky springs to match the junky struts. Hence the rust. Similarly assume the spring seats, strut mounts and other hardware are junky until proven otherwise. Is either spring seat broken now?
cn90 wrote: 01 Mar 2022, 20:42 ... If the strut is good, the individual coils won't touch each other.
This idea does seem possible but we've never seen or heard of it before in however many forum posts so I'd go with Occam's razor - very unlikely, or unlikely with an actual factory spring at least. Especially given that this car has such very low mileage. As above, a junky spring might make more sense.
Are there other signs of sketchy maintenance history where Volvo parts were swapped for imposters? Speaking of coils check the ignition coils - did they change them out for no-name ones?
Also those coils (springs) look unusually close together right now with the car at rest, unless that is just the camera angle.
