850 6 CDs charger
manovlov
Has thanked: 673 times
Been thanked: 164 times
Post by manovlov »
Hy Buddies,
One of my disc is blocked in the charger so i can't get the 6 cds cassette out. Does anyone has an idea on "how to" about this issue ? I have also found these o rings but don't know if they have to matter with the cd charger...
May i use silicon grease to keep the stuff in good shape ? (on springs, arms teeth wheels...) ?
Manov
cd charger 2.jpg (106.1 KiB) Viewed 1196 times
cd charger 1.jpg (222.4 KiB) Viewed 1196 times
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Looks like you might be beyond this, but in the past when I had a CD stuck in the head unit, I'd slip a piece of thin cardboard in the CD slot while hitting eject. But I don't know if that's even the issue your having.
1999 V70 GLT
manovlov
Post by manovlov »
Hello Sveedy,
The disc is out without any damage. I still questioning myself about the 2 rings...
Thanks for your help.
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Were the o-rings loose inside the CD changer ? They would seem to be out of place. Another member of our little tribe was having problems with a radio with the CD player, and once he got it out og the car and shook it, some coins fell out. Maybe your o-rings are the result of some child's adventure.
I would be careful with any type of grease, it could get places you don't intend. If lubrication seems to be needed, my suggestion would be some silicone spray on a cotton swab; you can be much more precise with placement and quantity of the lube.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
foggydogg wrote: 21 Feb 2022, 08:43 Were the o-rings loose inside the CD changer ? They would seem to be out of place. Another member of our little tribe was having problems with a radio with the CD player, and once he got it out og the car and shook it, some coins fell out. Maybe your o-rings are the result of some child's adventure.
The silicone grease is probably fine. I would only apply it where there is/was factory grease, however. Moving parts in electronics do get grease, but cleaning off any old dried original grease may be complicated if not disassembled... which might be more than the OP is up for.
The OP might try joining Audiokarma and asking in the DIY section.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
manovlov
Post by manovlov »
Thanks Guys, i will rebuild my cd charger for the moment and test it.As say earlier, the o rings don't seem to have their place in this "machine". I will tell you if everything works.
100 % okay with the silicon spray and the cotton swab, alos.
Manov
manovlov
Post by manovlov »
Hy Guys,
A little question : does someone know if the cover part N° 14 fits for the bracket N° 16, or should i find the part N° 7 ?
Manov
Cover charger.jpg (79.11 KiB) Viewed 1117 times
