96 850 R turbo break up
Flametrap666
- Year and Model: 96 850 R
I just purchased a 96 850 R.. when I dump the throttle and it pulls boost it hits about 4k bogs down and back fires.. check engine flashes due to the car misfiring on more than one cylinder. Its running a tune but I don't recall the brand as the car is 2 days new to me. I find it hard to believe it's related to the tune and feel as if something a little more sinister is happening. I've owned a lot of Volvos over the years but have never owned something with a tune and high pressure turbo. Please help with any possibilities of why this could be happening. I'm only looking for experienced people to respond as we know unfortunately lots of "Parrots" exist on these sites. Thank you in advance.. (New guy with 96 850 R)
Khyren
- Year and Model: 1998
- Has thanked: 3 times
I had a Turbo Thunderbird years ago that would backfire at anything above 14psi. Turns out, it was a weak fuel pump that didn't have enough flow for the higher demands above that boost. I would check your fuel pressures, spark plugs, and maybe even ohm the coil if it is having the spark blow out.
- Been thanked: 4068 times
Are all your ignition components stage 0?
These cars run open loop on boost so the tune has to be dialed in precisely to the turbo and induction by the tuner.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
As mentioned above, what is the fitness of your ignition components?
Have you checked all of your hoses between the turbo and the intake?
Do you have a stock ECU to toss back in it?
- Has thanked: 311 times
- Been thanked: 817 times
If it cuts out with RPMs check ignition, if it cuts out with PSI check the CBV diaphragm especially if it wasn't refreshed recently. Swapping the ECU is a great troubleshooting idea.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
+1 on all above.
These cars really prefer OE ignotion parts, especially the spark plugs and wires, distributor and rotor.
My 96 R did the same thing as yours on the stock tune when I bought it. After refreshing all ignition components it really came to life above 4000rpm.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 2857 times
- Been thanked: 1332 times
My first thought while read the lead post. Besides looking for the simple things like blown off vacuum lines and the condition of the spark plugs, I'd swap in a stock ECU. You don't even need to buy one if you know of or can find a friend with a HPT 850.
If it's not that, then what Abscate said... look at Stage 0 checklist.
- 758 Views
Last post by GDiode
- 17 Replies
- 2904 Views
Last post by Klausc
- 2330 Views
- 2811 Views
Last post by mkc1
- 5274 Views
Last post by precopster
