Here's where I found to buy Norma clamps. Nobody has prices so I assume they only sell in large bulk.
Norma - https://shop.normagroup.com
Red House Supply in NJ - https://redhousesupply.com/
Fastenal - https://www.fastenal.com/
Power steering pump leak?
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I'm not getting anything with the second link, and Google isn't helping.FireFox31 wrote: 21 Feb 2022, 22:33 Here's where I found to buy Norma clamps. Nobody has prices so I assume they only sell in large bulk.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
I think Firefox just made my day
Fastenal sells oetiker clamps in stainless in qty one at about $ 0.50 each.
Time to catalog all my hose clamps on a P80, after I finish colour sorting my socks
- FireFox31
Weird, I found Red House Supply in 10/2021 and the site was functional. Google still returns results when searching for "red house supply", but the links don't work. Maybe a temporary outage, maybe permanent. They had lots of good hose clamps.
I've been making note of the Norma part numbers on clamps that I work with. From my notes:
Stainless classifications, per Red House Supply:
W2 - galvanized screw, 430 band
W3 - 430 screw, 430 band
W4 - 304 screw, 304 band
W5 - 316 screw, 316 band
Specs - https://powered-by.qbank-mediaportal.se ... eet-en.pdf
The link to the spec sheet is also broken now.
FireFox31
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
SOURDOUGHJIM
- Year and Model: 2004 V70 2.4
- Has thanked: 55 times
- Been thanked: 28 times
This appears to be my problem as well. Oil drenched engine front and half the oil pan. (Leaked fluid is green)
Pump has been recently replaced. Reservoir and supply hose look suspect.i washed it off with Super Clean. I'll see how it does tomorrow.
SOURDOUGHJIM
Dixon Wave Seal clamps would be a good choice as well. A bit spendy though.
https://dixonvalve.com/en/products/waveseal-clamp
- FireFox31
On two different 2000 V70s, I noticed that newly installed reservoirs swelled quite quickly after install. The system is pressurized and that causes the expansion. It's a common problem that expansion for 10+ years causes leaking at the horizontal seam. I'm saying that swelling is common immediately thus not an indication of failure in itself. As you did, it's best to clean the tank and check for leaking at the seam.
I've also experienced leaking at worm gear clamps because I failed to tighten them enough. Fluid drips down on to the seam making it look like the seam is leaking. Be sure to tighten the clamps firmly.
FireFox31
rrres
- Year and Model: 1999 v70XC
- Has thanked: 12 times
- Been thanked: 34 times
Did the new hose and clamp(s) fix the leak?C1ph3r wrote: 19 Feb 2022, 11:37 Thanks everyone. I’ll get on all those recommendations as funds allow. I have very quickly exceeded my budget for repairs when I started down this rabbit hole. So now I’m really have to pick and choose my battles with the must replace vs would be nice to replace.
I recently had to remove the power steering pump to access the alternator. Now that everything is put back together, my power steering pump has that same looking leak. I can see ATF drip-drip-drip on the oil filter after driving. I had to top off the fluid last week.
I cleaned the area around the hose clamp and hard line fitting and the leak doesn't seem to be coming from those two connections. Is there anywhere else on the pump where the fluid can leak?
It's blowby
- C1ph3r
- Year and Model: 1999 V70T5
- Has thanked: 32 times
- Been thanked: 7 times
Did the new hose and clamp(s) fix the leak?rrres wrote: 07 Jul 2025, 12:38 [quote=C1ph3r post_id=594635 time=<a href="tel:1645295874">1645295874</a> user_id=112330]
[/quote]
Oh man. Wow. I honestly can’t remember what I did. I put a new used worm gear clamp on it but didn’t change the hose. I’ve not had any PS leaks so that must have done the trick. Sorry it’s just been forever.
1999 Volvo V70 T5
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
1970 Chevrolet C10
2006 Acura RSX
2016 Subaru Impreza
1975 Honda CB360t
