Oil capacity of rebuilt engine Topic is solved
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
^ So then maybe just about 7 qts if it's a turbo with a dry engine, lines, turbo etc.
1999 V70 GLT
1999 V70 GLT
Don’t sweat it too much Sveedy. Turbos have the piston oilers so as long as the oil pump is making pressure everything is getting lubed well from 4 liters of oil on up
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
No, 6.5.Sveedy wrote: 18 Feb 2022, 07:40 ^ So then maybe just about 7 qts if it's a turbo with a dry engine, lines, turbo etc.
- Sveedy
First oil change today. Drained, replaced filter, added 6 qts. Shows full on the stick !
So since I was only showing 1/2 way on it with 6.5 qts after rebuild, it seems that a dry engine will actually need a full quart more ( 7 ) than normal oil change.
1999 V70 GLT
1999 V70 GLT
Is that full after starting and running To temperatureSveedy wrote: 26 Feb 2022, 17:47 First oil change today. Drained, replaced filter, added 6 qts. Shows full on the stick !
- Sveedy
Yes. Normal operating temp in both cases.
7 makes sense if you consider that we typically add 6 for a change w/ filter, and manual calls for another 1 for dry turbo lines.
1999 V70 GLT
1999 V70 GLT
- June
- Has thanked: 523 times
- Been thanked: 261 times
Incidentally my dealer puts 7.5 quarts in my 04 2.9L T6 during a routine oil and filter change. The oil level is always perfectly on the full line. I have carried umpteen boxes of Redline oil to them to get 4.5 quarts back. Sometimes 8 quarts to find one bottle half full wrapped in plastic left. I once asked why the extra .25 quart since the manual calls for 7.25 quarts used to perfectly fill to full. The explanation was Volvo at some point revised the fill recommendation to 7.5 quarts for my engine and provided a updated dip stick to reflect full with the extra oil. I vaguely recall the dip stick being different years ago after a service. I wander if the 5 cylinder had a increase as well? June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
There was a dipstick change on the P80 , and replacement dipsticks read slightly different than originals. I think there is also a tube change, it’s been discussed here of course.
The oil level just isn’t that critical in these cars. Being on the bottom of the hash marks isn’t “ worse “ than being at the top. As long as the oil pump has full suction, the oil pressure throughout the engine is the same. This probably occurs down the 2 liter level, not an experiment I’m interested in running.
If you are 2 liters low, your life will be shortened by rough;y 2/6 , but again if you are using synthetic with 5000-7500 intervals, you wouldn’t notice it
- 2334 Views
Last post by BlackThunder
- 3560 Views
Last post by donc
- 331 Views
Last post by magna224
- 2036 Views
- 12 Replies
- 3478 Views
Last post by misha
