Bob Morton
- Year and Model: 1998 S70 T5 SE
- Been thanked: 8 times
I'm not sure what you mean by salt roads.
I live in Victoria, BC. We have "winter" from January 15 to Feb 28. Admission: I've never owned a can of penetrating oil
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Haha! But you didn’t mention the year-long Rain Festival!
I spy blue sway bar.
- Has thanked: 316 times
- Been thanked: 531 times
Oh yeah, 4 bolt control arms suck. 2 bolts are far better.
Bob Morton
Not too much rain here. Victoria is the 10th driest city in canada.BlackBart wrote: 07 Mar 2022, 08:25 Haha! But you didn’t mention the year-long Rain Festival!
https://victoriaweatherandclimate.blogs ... opulation.
I've got the track spec iPd sway bars, which I think aren't made anymore, at least they don't list the 25mm rear bar on the site.
- Has thanked: 1611 times
- Been thanked: 4074 times
Re installed fuel line on the S70 AWD back to factory rigging and installed under car cover. Double clamped the hose with 153 oetikers
Still can’t get any brake fluid through left rear caliper.
Have you tried cracking the brake line loose to bleed it that way? Probably a blockage in the caliper.abscate wrote: 08 Mar 2022, 15:29 Re installed fuel line on the S70 AWD back to factory rigging and installed under car cover. Double clamped the hose with 153 oetikers
Vegas is running an over/ under onbmdubya1198 wrote: 08 Mar 2022, 18:59Have you tried cracking the brake line loose to bleed it that way? Probably a blockage in the caliper.abscate wrote: 08 Mar 2022, 15:29 Re installed fuel line on the S70 AWD back to factory rigging and installed under car cover. Double clamped the hose with 153 oetikers
Bad master cylinder
Hung up ABS MANIFOLD
plugged/ kinked brake line
Bad brake hose
Plugged caliper
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Did an oil change.
Happy to report no coolant in the oil though. Timed the change well as it was a bit brown but not black. No big particles in the oil either.
Did full synthetic 5w-30 and car seems to run well.
Going to do plugs, fluid reservoir and a drain and fill in the coming days.
2008 S60 2.5T Auto (Sold)
- Has thanked: 987 times
- Been thanked: 1078 times
My bet is on the plugged caliper. Remove brake supply hose to this wheel and try to pull fluid/air thru the bleed screw using vacuum pump. If no fluid moves, poke an insulated, braided electric wire (this should not damage anything inside the caliper) in the inlet and outlet and twist to break up junk.abscate wrote: 08 Mar 2022, 19:46Vegas is running an over/ under onbmdubya1198 wrote: 08 Mar 2022, 18:59Have you tried cracking the brake line loose to bleed it that way? Probably a blockage in the caliper.abscate wrote: 08 Mar 2022, 15:29 Re installed fuel line on the S70 AWD back to factory rigging and installed under car cover. Double clamped the hose with 153 oetikers
Bad master cylinder
Bad brake hose
Plugged caliper
