I may have posted awhile back something on this topic and another member had responded by stating to try and turn the key to the accessory position twice and then turn the key fully to start the engine.
This seems to work lately and I just wondered if my starter motor is on it's last leg.
My P2 has 173k on her and I recently replaced both the alternator and the battery. Any opinions?
Starter Motor Life?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
This video below helped me diagnose my starter. The POS-II twice thing is odd to me. You need to do that in order to start the engine? The only thing I can think of doing that for is maybe to prime the fuel and vacuum pumps? Do you have fuel pressure at the rail when you let it sit overnight?
04s60 2.4
04xc70 2.5t
04xc70 2.5t
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Check fuel pressure in the ramp, it could be a weak fuel pump.Mr. Detail wrote: 08 Mar 2022, 08:54 I may have posted awhile back something on this topic and another member had responded by stating to try and turn the key to the accessory position twice and then turn the key fully to start the engine.
Mr. Detail
How do I do that? Check the pressure in the ramp? Special tools needed?
vtl
Yes, Schrader valve on the ramp. Something like that is needed: www.amazon.com/BETOOLL-0-140PSI-Injecto ... 00VV29NHM/ Can get one at Autozone, etc.Mr. Detail wrote: 09 Mar 2022, 06:27 How do I do that? Check the pressure in the ramp? Special tools needed?
Fuel pump primes the pressure when key is in position II. Engine needs 400 kPa of pressure to start (and work).
Mr. Detail
Thanks much vtl!
- Been thanked: 4064 times
Do you need two turns of the key to CRANK or two to turns to START ?
First is a starter problem, second likely fuel delivery problem.
At 150,000 miles, it’s a hood time to clean out the pcv system on a P2. When you do that , the starter is a5 minute removal. Take it to an auto electric shop and have it rebuilt for $100
Repeat every 10 years
Mr. Detail
I turn the key to the accessory position twice to start or turn over the engine.
Mr. Detail
If it is "fuel delivery" does that mean a dying fuel pump?
- 973 Views
Last post by SuperHerman
- 5018 Views
Last post by ggleavitt
- 705 Views
- 10 Replies
- 3452 Views
Last post by Rvolvos
- 3235 Views
Last post by sheaton
