I like this for engine assembly lube: Lubriplate No. 105
Cam cover installation tools.
- Has thanked: 987 times
- Been thanked: 1075 times
- Lubriplate 105.png (58.49 KiB) Viewed 590 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Can't remember where I saw it but cam cover draw down tools can be made from old spark plugs, knock the porcelain out and weld a length of all thread rod in, use matching nuts and fender washers to draw the cover down.
I think it was shown in the Haynes printed service manual....along with the homemade cam shaft locking tool made from angle iron.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
The top of the head that mates with the cam cover has stains that do not come off. Is this okay?
Since the oil is drained, and the engine has been sitting a while, is it okay if I rotate the engine with the cams and timing belt installed to make sure no valves are hitting?
Also, the exhaust cam is vvt, and I never took the vvt hub off. What do I have to do differently for aligning it properly?
2002 v70 X/C 288k miles
And the camshaft thrust surface on the first journal from left. I left that bare and it took me 6bweeks to figure out why my cams locked upvtl wrote: 12 Mar 2022, 14:35 Looks ok to me.
Don't forget to lubricate camshaft valleys. Tappets, too.
- 02V70
I almost forgot to do that. Thanks!
Also, is it safe to turn the engine manually if there is no oil in it? Since I have a vvt cam (I never took the hub off) the gear should be aligned instead of the cam right?
- 2737 Views
Last post by matthew1
- 1241 Views
- 1630 Views
Last post by 93Regina
- 884 Views
Last post by mp5802
- 10 Replies
- 1117 Views
Last post by Antoine240bk
