What too much crankcase pressure looks like
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
Here is a short video of a Chevy Equinox 2.4L Ecotec engine with a plugged up PCV system. I know it's not a Volvo or a turbo engine but Volvo's can and do have PCV issues, high crankcase pressures and blown seals if not maintained. The crankcase pressure gradually builds up to almost 2psi and what I found most interesting is the amount of pressure released when the oil filler cap is removed at the end of the video. This car (my daughter's car) has a horrible rear main seal leak when running and you can see why from this test. These engines are known to have PCV clogging issues and blown rear main seals, a very expensive repair. It's best to keep a good eye on the PCV system to avoid nasty repairs like this one. One solution to save the rear main seal for this particular engine is a vented oil filler cap that vents the crankcase pressure if it gets too high from a plugged up PCV system.
Why does it have to be the rear main seal that fails? The most time consuming and costly seal to replace.
PCV TEST.mp4
(17.6 MiB) Downloaded 379 times
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
Put an air hose on the oil fill cap and inflate your tires!!
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
