P80 radiator mount rubber washers 9180544 1021912
Been thanked: 4069 times
I’m missing these on the T5 but can’t find a part number in webstore
These are important as they absorb vibrations which aren’t going to be hood for the plastic aluminum joint on the radiator
….and Skandix for the win…
rrres
Year and Model: 1999 v70XC
Has thanked: 12 times
Been thanked: 34 times
Post by rrres »
This is good to know. I once ordered a Nissens radiator from Rockauto and when it came time to install, found out it didn't include the rubber bushings. Then those bushings installed in the spectra rad I was replacing were somehow molded on and had to be sliced to be removed.
It's blowby
Has thanked: 2205 times
Been thanked: 1852 times
Some places show this as NLA. I may have a spare 'somewhere' if you don't have luck locally.
Just pulled two off Jane Bond… you only live twice
Excellent!
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Welp today is the day I learn there are supposed to be rubber mounts there :?
Another thing to put in my next skandix order :D My Nissen radiator didn't come with them and previous owner must have thrown them away
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Goupil wrote: 30 Mar 2022, 15:24 Welp today is the day I learn there are supposed to be rubber mounts there :?
I too, learned this in March 2022. I’ve been running it since 2013 without these. I’ve also ruined a radiator , probably from vibration. Use stainless nuts and bolts to hold these in. It’s a real rust spot
