Nevada1906 1995 850 S60R m56 build thread
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Seems like it would be pretty tight clearance from the top with the turbo and accessories already mounted. I took all of that off before pulling the engine; would sure be nice to do all of that prior to installation.
1999 V70 GLT
Nevada1906
Year and Model: 1995 850 Turbo
Been thanked: 30 times
Post by Nevada1906 »
Sveedy wrote: 03 Dec 2021, 17:51 Seems like it would be pretty tight clearance from the top with the turbo and accessories already mounted. I took all of that off before pulling the engine; would sure be nice to do all of that prior to installation.
Yeah, I think I stripped as many parts off as I could - including the head, which is where this adventure started - before I lifted the old one out, but I'm not taking anything on this engine off before installation unless I absolutely have to.
"Maturity is when you realize that the overbearing high school principal or villainous college dean from your favorite 80s movie is actually the hero of the story."
1995 860R (854 + B5254T4 + M56)
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I normally pull these engines and transmissions from the top, with the AC compressor and PS pump disconnected so I don't have to drain/evacuate those systems. If you're using a load leveler, it's very doable. Just have to do a little bit of wiggling and tilting.
Nevada1906
Life got in the way again. I finally got some things done.
I cleaned up the front subframe:
Then added new mounts and reintalled it in the car:
Then installed the sway bar, steering rack and shift cables:
The next step is to get the exhaust out. Nice of Volvo to WELD the entire thing together...
Been thanked: 4071 times
Volvo didn’t weld it together, that’s on a previous owner
Are you really doing to put that subframe in with that rust?
MVSarchasm
Has thanked: 2205 times
Been thanked: 1852 times
I was thinking the same. After going to all that work I would have had it painted at least before refitting. Ideally powdercoated before fitting the sub-frame mounts.
Good luck!
No need to powdered coat in those warm climates.
Nevada1906
scot850 wrote: 27 Mar 2022, 10:33 I was thinking the same. After going to all that work I would have had it painted at least before refitting. Ideally powdercoated before fitting the sub-frame mounts.
Good luck!
Believe me, I'd absolutely LOVE to vaporblast and powdercoat every single part on this car, chassis included. Unfortunately, something broke inside me last month and now, I JUST WANT MY CAR BACK. I'm sick of looking at it sitting forlornly in the garage, half-apart, surrounded by parts leaned up against walls, stacked on benches, laid in corners, stuffed under the car itself.
Also, I don't have a vaporblasting cabinet or a powdercoating setup, nor do I have the cash for them right now. But not to worry - all the TTY bolts I've replaced are new and installed properly. Everything's sealed and gasketed up nice and tight. It'll be fine.
If it turns out to be a Swedish rat rod, so be it. At least that keeps the car tax on the ground.
I noticed that. Bravo Zulu
You have to go with what health, time and wealth is available. Go for it and as said before we wish you lots of luck!
