Volvo Term Glossary
nascenta
Year and Model: 850r t5
Post by nascenta »
I have found this glossary very useful. Thanks for creating it. Three terms to add though, FPM (fuel pump module), FPCM (fuel pump control module) and PEM (pump electronic module). Apparently, is the same thing but given a different name depending on the model.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
PTC Positive Temperature Coefficient (heater nipple)
... added.
Thanks nascenta and philopus.
Also -> Amazon link
Ben850
Been thanked: 7 times
Post by Ben850 »
VVIS - Volvo Variable Induction System.
This applies to the '93 - '94.5 850 intake manifold with a vacuum actuated vane to switch between a long or short runner within the manifold at a set RPM for torque, and/or fuel savings.
Side note: They function better when the actuation order is reversed with a device that fools the electronic vacuum solenoid as to RPM.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
nascenta
Post by nascenta »
CPS also stands for clutch position sensor.
matthew1
Site Admin
Post by matthew1 »
Updated. Thanks guys.
Also -> Amazon link
Has thanked: 1609 times
Been thanked: 4065 times
STC -Stability and Traction Control. In 1999, with engine torque management handled in software ( Bosch ME7) the earlier TRACS system was upgraded to include AbS control of all four wheels, and torque management for enhanced stability and traction.
SWMBO- S/he Who Must Be Obeyed… usually aimed at married guys
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
I need this glossary badly, just to keep up with the MVS thread banter!
So... clarify please -
I've always said "ECU," in newer Volvos it's a CEM, but....
I take it the ECU still controls specifically engine management, and the CEM is the overall computer managing all the other systems?? Is that accurate?
P80s have ECU or ECM but no CEM. Sometimes the main fuse box is called the CEM but it doesn’t have processors like the P2. Potato, potaato.
P2s have both ECU and ECM for engine management and a CEM Which manages most/ all the other modules
matthew1
Site Admin
Post by matthew1 »
abscate wrote: 29 Mar 2022, 06:16 STC -Stability and Traction Control. In 1999, with engine torque management handled in software ( Bosch ME7) the earlier TRACS system was upgraded to include AbS control of all four wheels, and torque management for enhanced stability and traction.
Added. Thanks Abscate.
Also -> Amazon link
BlackBart
Post by BlackBart »
abscate wrote: 30 Mar 2022, 04:53P2s have both ECU and ECM for engine management...
Both...!?
