Rescuing Geronimo the 2000 V70
Has thanked: 2207 times
Been thanked: 1852 times
Yes they do have the same length. Forgot about them using the shorties. I wounder if P2 lugbolts would work?
Has thanked: 1611 times
Been thanked: 4072 times
I’ve got a huge box of lug bolts. Can you post the needed size?
If it helps abscate, the bolt/thread section from the cone area is the same as the regular 'tall' headed chrome bolt. The difference is the head itself. It is about half the height more like a P2 bolt but without the loose collar:
https://www.ebay.com/itm/361577930284?f ... Swdj9XToOc
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
scot850 wrote: 24 Mar 2022, 19:15 In Europe around the early 90's that style of wheel was fairly common. I had something similar fitted to my Vauxhall Carlton 3000 GSi as aftermarket wheels to replace the horrid OE wheels: This is what the car looked like, but not the wheels. They were a 6 spoke rounded spoke wheel like the Cetus:
https://picclick.co.uk/1987-Vauxhall-Ca ... 47179.html
wow, a 3 Liter Opel Omega in British disguise. Always wanted one of them. By the time I had my driver's license in 1998 they were too rusty to purchase.
1996 855 R,
2010 V70 D5,
Mine had to have the whole hood replaced at 5 years old as it rusted through! In fact I had to have the whole car de-rusted and re-painted at that time. Rust was an issue.
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
I can't find my spare tall-head lug bolts to measure them. I trust the eBay link above that the rough measurements are: threaded section 1.5", cone 0.5", hex head 0.5" They are part 31280299. Thanks for checking.
FireFox31
You are welcome! They are also the bolts they used to supply with cars with steel rims and plastic wheel covers.
Good luck.
FireFox31
Post by FireFox31 »
Geronimo got its new (old) seats! The owner loves them, saying they brighten up the car (new are oak, old were beige). Thanks to abscate for pulling them from the V70 I donated.
What can I harvest from the old seats? Driver's adjustment motors and buttons, seat heaters, passenger's seat back? Is it easy to hack off the foam so I can take the metal to the scrap yard?
FireFox31
Pop the springs off amd the foam will fall off. There are five ? Heavy springs at the rear of the seat bottom which cone out with Channelocks and healthy hand pressure ( Caitlin pulled them off by hand, scary) then the bottom foam pivots up from the rear and out.
Pictures linked are in my Elizabeth maintenance thread , in the March 2018 diary, under seat reskin
I’m slowly filling the Maine box with parts again.
I’ve found a bunch of lug nuts with short heads. Rusty but will clean up nicely.
Brake bleeders
I think I have two intake VVT solenoids. Checking part numbers
Coolant reservoir bottle
HVAC damper motor NH…which one do you need? MCC or ECC? Part number best of course
