I need a working ETM manufactured AFTER 2013 for my 2001 XC Turbo.
I'm in New Orleans 70122
NEW TOPIC *** JUNKYARD REQUESTS *****
- Been thanked: 4071 times
These come up routine on eBay for $100-150 ( make offer at $125 or so)helmbelly wrote: 22 Mar 2022, 13:53 I need a working ETM manufactured AFTER 2013 for my 2001 XC Turbo.
Part number is in the ETM forum below
- BlackBart
- Has thanked: 967 times
- Been thanked: 923 times
Does anyone ever see the factory trailer hitch for the P2 XC wagon? It's the one that fits up inside the bumper cover, not the ones that hang down below.
Might be heavy and hard to ship.
Khyren
- Year and Model: 1998
- Has thanked: 3 times
I need an early, large flange rear differential viscous coupling for my 1998 V70 AWD. I need the two sholder bolts that hold the lower black plastic valance that goes into the bumper. And lastly I need a set of 03-04 C70 headlights. I have a Xemodex ETM that was taken off of a running 99 XC70 to sell or trade.
Edit: I need the VC on the left and I have the one on the right.
- Has thanked: 316 times
- Been thanked: 531 times
See belowhelmbelly wrote: 22 Mar 2022, 13:53 I need a working ETM manufactured AFTER 2013 for my 2001 XC Turbo.
Helmbelly above here may be interested in that. The '99-'01 ETMs are all compatible, seeing as it's from a turbo car going onto a turbo car.Khyren wrote: 29 Mar 2022, 22:02 I need an early, large flange rear differential viscous coupling for my 1998 V70 AWD. I need the two sholder bolts that hold the lower black plastic valance that goes into the bumper. And lastly I need a set of 03-04 C70 headlights. I have a Xemodex ETM that was taken off of a running 99 XC70 to sell or trade.
- Has thanked: 2207 times
Sorry to be dumb, but I don't understand what you are talking about on the black plastic cover and the shoulder bolts.
I have 2 viscous couplings but unfortunately I don't have the earlier version. That went to Anchorage!
Khyren
I'll get a picture of that plastic piece and where the shoulder bolts go. My plastic piece may just be drilled out and they put those bolts in there to fill the hole.scot850 wrote: 30 Mar 2022, 19:40 Sorry to be dumb, but I don't understand what you are talking about on the black plastic cover and the shoulder bolts.
That would certainly be a help.
Could you run the later viscous coupling with the later, longer driveshaft?Khyren wrote: 29 Mar 2022, 22:02 I need an early, large flange rear differential viscous coupling for my 1998 V70 AWD. I need the two sholder bolts that hold the lower black plastic valance that goes into the bumper. And lastly I need a set of 03-04 C70 headlights. I have a Xemodex ETM that was taken off of a running 99 XC70 to sell or trade.
Edit: I need the VC on the left and I have the one on the right.![]()
I think there are three versions of late p80 AWD driveshafts/couplings, so watch out for that
I believe you can, assuming it will bolt up to the diff. The whole angle gear/driveshaft/VC setup is interchangeable.abscate wrote: 10 Apr 2022, 04:10Could you run the later viscous coupling with the later, longer driveshaft?Khyren wrote: 29 Mar 2022, 22:02 I need an early, large flange rear differential viscous coupling for my 1998 V70 AWD. I need the two sholder bolts that hold the lower black plastic valance that goes into the bumper. And lastly I need a set of 03-04 C70 headlights. I have a Xemodex ETM that was taken off of a running 99 XC70 to sell or trade.
