OBD Port no power 98 v70xc
esl_97_850_T5
Year and Model: 1998 S70 GLT
Has thanked: 18 times
Been thanked: 27 times
Post by esl_97_850_T5 »
In my USA '98 S70 GLT, the fuse controlling OBDII diagnostics (and climate control) is small fuse #5, 15A, in the Supplementary Fuse Box (that has slots for 36 small fuses). Supplementary Fuse Box is under the hood, in the USA driver's side corner, very close to the windshield.
The lid of the Supplementary Fuse Box says something like the following for fuse #5:
Climate Control, Diagnos.
The S70 User's Manual lists the Supplementary Fuse Box fuse #5 as something like:
OBDII Diagnostics.
Again, all these comments are for my USA '98 S70 GLT.
Not sure if they are applicable to your car.
1998 Volvo S70 GLT - 205.5K miles - S70 & M44 testbed in 2016-2019; traded 2019-07-15 (for spare time)
1997 Volvo 854 T5 - 147K miles - 850 testbed in 2012-2017; junked 2017-09
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Post by surfbug1 »
esl_97_850_T5 wrote: 24 Jan 2019, 14:57 In my USA '98 S70 GLT, the fuse controlling OBDII diagnostics (and climate control) is small fuse #5, 15A, in the Supplementary Fuse Box (that has slots for 36 small fuses). Supplementary Fuse Box is under the hood, in the USA driver's side corner, very close to the windshield.
OBDII Diagnostics.
Yes I have the same on my 1998 Volvo V70 GLT
The above info is correct and accurate.
Hmmm my fuse is good, but the obd is still not working.
Any ideas?
Thanks!
Big Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
Has thanked: 2200 times
Been thanked: 1852 times
Has anyone removed the center console? Could be as simple as the connectors have not been re-fitted or re-fitted correctly. Also worth checking no one has spilled a drink in there. To check you will have to remove the parking brake plastic panel. Careful not to break the pins.
Parking brake lever cover
Connectors under parking brake console cover
Hope this helps.
surfbug1
Post by surfbug1 »
scot850 wrote: 31 Mar 2022, 10:28 Has anyone removed the center console? Could be as simple as the connectors have not been re-fitted or re-fitted correctly. Also worth checking no one has spilled a drink in there. To check you will have to remove the parking brake plastic panel. Careful not to break the pins.
Hope this helps.
Ok ,cool.
Will try that! Thanks
Ping me!
:D
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
There is fuse in the fuse box for OBDII and it's shared with cigarette lighter and some other accessories.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
