Modifications and part numbers to the water pipe and heater core hoses variations between 1999 and 2000 models are in this thread
viewtopic.php?f=9&t=87749&p=570610&hili ... pe#p570610
1999 2000 MY - The "Bastards" Draft Info Thread
Well, presently in my extended family we are running
1998 v70 NA m56 with some bastardly features
1999 S70 NA full bastard
1999 V70 NA full bastard
1999 S70 AWD AT full bastard
1999 T5 M56 full bastard
And a 2000 M56 parts car
Combined mileage 990,000 miles
Link to discussion of 1999 2000 different power steering hoses.
https://www.matthewsvolvosite.com/forum ... hp?t=99756
Vida says to remove oil lines….on any car in weather getting these off without dropping the subframe is a fools errand. These hoses cost $125-300 each, so plan carefully.
Information
The power steering supply line routes pretty close to the -1998 version, but the fitting at the pump is different.
The power steering return line is completely different as the reservoir moves, it comes up aft of the engine. The fitting on the return line to the rack changes to soft alloy which you have to be really careful not to cross thread or round off.
Threads are the m18x1.5 to be confirmed and the seals are o-ring flange on the ps lines
Information
Appearance of the biscuit oil cooler
Turbo models 1999
NA models 2000
Might be an engine number break on this item
Noteworthy that the 1999 NAs didn’t get the biscuit oil cooler. At least not my early engine number models. Then magically,in 2000, they appear. More info for the bastards thread.
Turbo models 1999
NA models 2000
- Has thanked: 2200 times
I didn't think the NA's had an oil cooler, only the Turbos. Wonder why they would have added it to the 00 year?
- Has thanked: 316 times
- Been thanked: 531 times
I don't remember, they probably added it on NAs eventually (likely 2000). I know the early NAs didn't have the radiator mounted oil cooler.
'99 NAs were weird. My cousin's had no VVT, W917 oil filter, and no oil cooler.
Sounds about right for Volvo part change overs!
Owners manual for the 1999 s/v70 serpentine or drive belt has the wrong diagram in it. It shows the -1998 one.
In my 2000 in NA, they deleted the incorrect diagram
FYI , serpentine belt replace interval is 60,000 miles
Correct one here
Correct one here
