VIDA 2014D_Repack install on Windows 10, any version.
testing4567
- Year and Model: 97 850
Robopat
- Year and Model: 2013 S60 T5 AWD
Hello again,
I got Vida running, I entered all vehicle information, I plugged dice unit run diagnostic test for dice says ok but read vehicle doesn’t work.
When I first open Vida read vehicle is highlighted and works for a minute and after 3 sec stops.
Any guidance you can give me on that?
Thanks
Thanks
- RickHaleParker
- Been thanked: 979 times
Make sure partner group is set to AME ( American ). Then click [read]. You don't need to fill out all the information, [read] will find it. The easy way not to forget this is to login with a 2.Robopat wrote: 01 Apr 2022, 12:38 Hello again,
Active
Past
Past
Robopat
Hey Rick,
It is set to American when I press read it does it for about 10 secs and read stops and from there only dice configuration is highlighted read vehicle.
I was looking at one of your earlier posts and you said to make sure IE hosting is set correctly but I can’t find the file to do that.
Robopat
Hello everyone,
I think I had the dice working, I run tests from the file and everything checks ok.
Before I read the car I run the diagnostic on Vida checks ok.
Before reading the car information and diagnostic tabs are inactive once I read vehicle only information tab gets highlighted and operational but diagnostics stays off.
Anybody have any suggestions?
Thanks in advance.
Thanks in advance.
- Has thanked: 2857 times
- Been thanked: 1332 times
Hi Robopat
Can you please create a new topic for this? It's now squarely into DICE territory, and this thread is VIDA install.
Robopat
Hello everyone,
Thanks in advance.
Thanks in advance.
Robopat
Hey Matthew,
Sorry about that,
I sorted everything out with dice. Now I just have a bunch of codes that don’t go away.
Thanks for your help on this topic and thanks to Rick Hale for his help.
Sorry about that,
- 11182 Views
Last post by Stasiuss
- 5046 Views
Last post by big305
- 6015 Views
Last post by RickHaleParker
- 3162 Views
Last post by rusty volvo
- 4517 Views
Last post by wizechatmgr
