Best xc90 first gen
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Reasonably subjective request.
Most everything after 2009 is the I6 3.2 (you can find a few V8s until 2010) and it's a decently reliable powerplant. If you can find a 2011+, there are some minor transmission improvements for mileage but it's nothing of any great importance. You will, however, enjoy the last exterior refresh. If you purchase a latter model year, you'll see some vehicles with an Executive badge. These variants have some extra interior options (carpet, seats, trim) and you might find them of interest. There's a R-Design in there somewhere, suspension is a little stiffer and it has a different speed sensitive steering module as well as larger wheels and a number of trim accents. Here are a couple brochures that you can have a look at:
https://personalizeyourvolvo.com/PDF_Br ... 20(US).pdf, https://personalizeyourvolvo.com/PDF_Br ... ochure.pdf
As always, service documentation is king around here as is a pre-purchase inspection (PPI) preferably by someone who knows this vehicle.
Others will have input, this is just my own high level observation.
Good luck in your search
Edit- add a couple brochure links
I am in the USA. I am looking to buy a first generation XC90. I need the V8. I am seeing them with between 120K and 160K for around 6-10k USD depending on year I can go over that, but I only plan on using for about 2500-5000miles a year to go to the beach which is about 30 miles away one way. Any rust or electrical problems I need to look out for? What year is best? What are the known problems in these?
- Has thanked: 2858 times
- Been thanked: 1332 times
I've never owned one, so I can't first-hand comment. Here's some 1st gen XC90 V8 info to browse.
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
There are a lot of XC90s approaching 200k miles and many that are over.
The very first high level question I would ask is what is your level of fixing and repairing vehicles. The single biggest issue plaguing 1st Gen XC90s is delayed maintenance, in any year and engine variant. The second question would be what are your needs?, such as a 3rd row, towing, winter AWD, etc. One thing that cannot be disputed is the safety of the XC90. The body is solid and the sheet metal is thicker compared to a Toyota or Honda. Also there are longevity rust issues with Toyota and Honda (see the latest with Honda CRVs) while the XC90 is more resistant to rust.
The engine that has been the most dependable/consistent in regards to not needing more than the scheduled maintenance is the 3.2. However, usually there is delayed maintenance and even Volvo’s own recommended service is too long, their main scheduled maintenance is at 150k miles when it should be at 100k miles. That said, the work is all top end, meaning from up top. The 3.2 also has the same transmission, axles, radiator, etc. as the V8, so these parts are over specced for the 3.2. The 3.2 does have the newest trims levels and you can find them with all the options.
The V8 runs hot in the same engine bay and is susceptible to oil leaks. The valve covers, timing cover, and even replacing the alternator due to oil dripping on it are not scheduled maintenance, but known long-term issues. Gaskets and seals are lower cost parts, but the overall costs depends on your wrenching level. With the V8 torque, the CV axles can wear out sooner than the 3.2. The transmission can have more premature issues compared to the 3.2 because the torque rating is only a little higher than what the V8 outputs. Are there good examples, yes, but look at service history, the previous driver (avoid if there are teenagers in the household who could potentially be launching the XC90), did they do items while in there-like when removing the intake manifold, did they do the valve cover gaskets and PCV, etc.
The 2.5t is a very well documented engine. That also means the long-term maintenance and issues are known. Some are the PCV, camshaft oil seals, o-rings and seals in & outside of the oil pan (people replace entire oil pan), cleaning or replacement of the throttle body, and the 2.5t came with a softer center diff sleeve called the angle gear sleeve (this can strip). The angle gear (center diff) sleeve is the Achilles heel of these Volvos, but more so with the earlier ones since the metal is softer. Sometimes shops will have old school thinking with the older 2.5t and use conventional oil. Carbon build up has and is an issue in clogging up PCVs, VVT channels/screens, oil passages. The 2.5t is tunable with its turbo and people have put a simple dependable Stage 1 tune without any hardware modifications. This can increase torque to over 300ft-lbs and horsepower to ~250hp.
All will probably need an entire front suspension overhaul, all fluids and filters changed, engine mounts, fuel pressure sensor, and maybe a steering angle sensor at some point. Good oil changes with synthetic oil is key for any engine. Volvo did not spec synthetic and their extended oil change interval of 7k-7,500 miles is too long as the oil breaks down and leads to carbon build up; it should be at 5k miles with synthetic. This is where maintenance history is important and you can check off some of these items.
With any used high mileage vehicle, you should expect to do some work yourself to save money. Also, with any used vehicle, you should always plan to set aside $2-3k for the next year because of delayed maintenance and anything that pops up. If you want to reach 200k miles, don’t try to stretch known maintenance items.
You could buy a Toyota SUV, but expect to pay 2-4x the price of an XC90. Honda Pilots, too many are repaired using cheaper parts, have used conventional oil, and there are still delayed maintenance items (adjusting valves, fluids, etc). The Pilot also has oil consumption issues related to the cylinder deactivation, oil leaks, etc. Both Toyotas and Hondas rust easier than the XC90 and they are not as safe as the XC90.
Do good searches on all forums for past discussions, regardless of which SUV you are thinking.
Good luck with your search!
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- 5457 Views
Last post by matthew1
- 9 Replies
- 5647 Views
Last post by June
- 504 Views
Last post by BlackBart
- 884 Views
Last post by FLXC90
- 4888 Views
Last post by jnormandeau
