If you have checked and there is likely no unmetered air then I would highly recommend swapping in a junkyard MAF at this point, to complete/confirm the diagnosis. Make sure it is a Bosch MAF.
Car stalls. Hard start. MAF questions
- Has thanked: 312 times
- Been thanked: 818 times
I hear you, worth a try. Yes you can clean it more easily with it out but I wouldn't bother.
surfbug1
- Year and Model: 1998 V70, 2006 S80
- Has thanked: 41 times
- Been thanked: 9 times
Okay the car has been running fine with the MAF disconnected but I can notice I'm getting worse gas mileage.
Is there a difference with the MAF on a 1998 V70 GLT which is what I have.
And a 1998 V70 r or a V70 t5 which is a MAF that I found on eBay
Can I put the v70r V70 t5 MAF In my V70 GLT
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
Ping me!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You need Bosch # 0 280 217 107
For pre '99 cars.
'99+ have Denso management.
For pre '99 cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
surfbug1
misha wrote: 05 Apr 2022, 09:45 You need Bosch # 0 280 217 107
For pre '99 cars.
Ok cool. Thanks!
May try to clean it with MAF specific cleaner one more time.
I used brake cleaner. (Maybe I messed it up with that? )
Should I try once more with MAF cleaner?
Al
Ping me!
Ping me!
- misha
After a brake cleaner it would be toast even if it had a chance to be cleaned with proper cleaner.
Don't waste your time and money in anything that isn't Bosch # 0 280 217 107.
You will be chasing your tail.
Used Bosch one from a junkyard would be better than anything aftermarket when it comes to sensors on these cars.
ECT,O2,Maf,TPS....etc...must be oem.
MAF connector can also be a culprit.
All of them eventually fail at this age.
After a brake cleaner you will need new one anyway...but if problem persists...maf connector is next suspect.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
surfbug1
Ok, got a MAF and it's the correct part number.
(Check the part, not the tag)
Part number 0-280-217-107
Will throw it in and see how it does!
Thanks for the info guys
Al
Al
Ping me!
Ping me!
- misha
Remove negative battery cable while installing new Maf in order to reset ecu and fuel trims.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
surfbug1
Ahhhh good call I didn't know that.misha wrote: 05 Apr 2022, 15:38 Remove negative battery cable while installing new Maf in order to reset ecu and fuel trims.
Then throw it in, hook back up neg term and start it up?
Anything else?
Ping me!
Ping me!
- 11 Replies
- 3482 Views
Last post by jjs70pdx
- 41 Replies
- 7286 Views
Last post by eriscentro
- 15 Replies
- 3446 Views
- 12 Replies
- 2440 Views
- 10 Replies
- 1984 Views
Last post by albertoVO5
